SuperHawk Forum
-   -   twin headlight system for hawk (https://www.superhawkforum.com/forums/general-discussion-30/twin-headlight-system-hawk-16822/)
chevy Nov 23, 2008 05:50 AM
has anyone attempted to replace the single stock headlight system, for a double like on current street bikes.
If Not....is it Possible?
:peepwall::caught:
Tweety Nov 23, 2008 06:26 AM
Yep... It's been done... One way is to swap the entire front end plastics... Apparently the CBR600 from some years can be made to fit... Also the RC-51 plastics can be fitted with some work...
The other is to swap out the stock headlight for a mounting for two smaller projector lights... Here is one example... http://cgi.ebay.com/ebaymotors/TWIN-...91110009r26902
Then there is the option to go with race plastics and make a totaly custom job your self...:)
chevy Nov 23, 2008 10:06 AM
Tweety
I didn't think it was possible, but with a group of guy's here at SH Forum any things possible.
I love the twin look.......really steps up the bike!
inderocker Nov 23, 2008 10:34 AM
There was a direct replacement for the single headlight that turned it into a double unit from Wild Hair Accessories. Pretty ugly and dated IMO...
http://www.whaccessories.com/VTR1000MET.jpg
http://www.whaccessories.com/MetisseVTR1000F.jpg
chevy Nov 23, 2008 10:46 AM
i like the yellow, this clearly gives me a better view!
kinda makes you think about what you really wanna do from this point, now seeing it on the bike.
Thanks Inderocker!
Tweety Nov 23, 2008 10:51 AM
I like this better...:)
http://www.tweety.se/gallery/HID%20B...g/PICT1695.jpg
Truckinduc Nov 23, 2008 11:38 AM
ANYTHING IS POSSIBLE
LineArrayNut Nov 23, 2008 02:10 PM
divide one by zero then...:rolleyes:
Reason Nov 23, 2008 04:28 PM
Looks good, Tweety, but it needs a little... something...
http://img179.imageshack.us/img179/5...1695acris9.jpg
http://img179.imageshack.us/img179/p...jpg/1/w600.png
There are some cool dual kits for streetfighters here, not sure how hard it would be to adapt, or if it'd be worth it. I like the Hesa Headlight fire myself, that vertical stack is nice.
http://www.streetfightersinc.com/Headlightkits.htm
http://img227.imageshack.us/img227/p...pg/1/w1024.png
Truckinduc Nov 23, 2008 09:25 PM
ok, http://thxforthe.info/blog/wp-conten...ed_by_zero.jpg
anything on a bike
Tweety Nov 24, 2008 05:01 AM
The girlies I like but the halo is a definete no-no...:) My bike is a no bling zone...:) It goes like crazy in the corners instead... It's so fun to do circles around the squids on blinged out bikes...
Altough if I do find a suitable shroud/ring in chrome or otherwise I will use that to cover the irregular shape of the projector itself... I like the clean black, but the way it looks is mostly to have it sealed up... No light leaking in the wrong places...
Byrdman Nov 24, 2008 06:38 AM
Originally Posted by Truckinduc (Post 189772)
very nice
LineArrayNut Nov 24, 2008 07:46 AM
well done truck, well done!
:thumbsup:
ok,
anything on a bike
LineArrayNut Nov 24, 2008 08:54 AM
They went to the trouble to make it look like a HID projector... then put incandescent bulbs in it... doesn't make much sense to me...
Tweety Nov 24, 2008 09:52 AM
Not to me neither... Altough the incandescent bulbs in a projector is a tad better than with an open reflector... They still suck in comparasion......:)
Erik S. Nov 24, 2008 10:45 AM
Tweety, is your HID a Low/High, or just low beam?
Tweety Nov 24, 2008 03:02 PM
Low/High... solenoid... It's from a nissan G35...
BTW look here for a gallery... Text is in Swedish so it might not be usefull... But there are a few more snaps...
Basicly what it says about the HID... The rear two bolts used to adjust the aim is functional... The projector is mounted on a "frame" of 2 mm aluminium sheet that is brushed matte and painted black... and uses the 3 internal mount points... one fixed joint and two bolts...
Iteration 2 will be prettier... I have figured out how to hide the two hex bolts from view and in that process I'm going to tighten up the gap in a few places around the projector...
Truckinduc Nov 24, 2008 05:46 PM
1 Attachment(s)
here are the projectors i picked up for 60 bucks, i plan on going HID with them but i have to test the housings first to see if they can take the extra heat.
Attachment 30108
Truckinduc Nov 24, 2008 05:48 PM
1 Attachment(s)
Attachment 30107
chevy Nov 24, 2008 08:10 PM
:peepwall:
