Throttle Cables
So, for the sake of my sanity I'm looking for some help. I recently finished up a 929 front end swap on the Superhawk and have spent more time than I care to admit trying to find a way for the throttle cables to work correctly. Currently I have them routed roughly the same way as it was and am experiencing binding problems at full lock left. If anyone has any pics of how they have their's routed could you post them?
Thank you. |
You can solve half the problem by just running a pull cable. Remove the push cable and the throttle action will be much lighter.
Also, give motion pro a call, tell them what you need. They have all the measurements for the cables, and could compare for you :) James |
Removing the push cable was the only way I could get my 929rr front end working without binding at full lock.
Run just the one cable. Its just not worth the headache for 2.
