Surging at cruising throttle
Old 05-26-2017, 07:50 PM
bristunt's Avatar
bristunt is on a distinguished road
Hey fellas, looking for some thoughts.
My wifes superhawk is surging at cruising throttle.
Idle is fine, and acceleration is fine.
Have checked:
Throttle position sensor good
Carbies balanced & bowls drained
Plugs changed just in case
Battery good
Reg/rec good
No vacuume leaks
No jetting changes since running good
Fresh fuel
Any thoughts
bristunt is offline
Old 05-26-2017, 09:14 PM
surging is typically related to a lean condition. How does it run at higher engine speed? A torn diaphragm in the petcock can also cause fuel starvation and create a lean condition (had it happen to me a couple times)
mikstr is offline
Old 05-26-2017, 09:31 PM
bristunt's Avatar
I've had a torn petcock diaphram before and it starved for fuel at full noise. This is rich if anything.
It's strange, good one ride, then a month later **** from startup. Even in neutral holding rpm anywhere above idle it is surging.
bristunt is offline
Old 05-27-2017, 08:03 AM
I would more suspect torn carb diaphragm or carb boots not sealed tightly. Carb boot tears are tricky to find to look closely. Reseat the carbs themselves an smear a bit of Vaseline around the mating surface to help.
As it happens carefully pull the choke a bit to see what that does. It should change it somewhat.
smokinjoe73 is offline
Old 05-27-2017, 08:04 AM
More likely clogged carb jets. Take this time to install filters in the fuel lines. I would drain the fuel and start fresh when you clean the carbs or more gunk will simply reclog in like 2 blocks.
Old 05-29-2017, 01:00 AM
sjscicluna's Avatar
Watching this tentatively.
sjscicluna is offline
Old 05-29-2017, 06:16 AM
tentatively?
Like you can take or leave the outcome?
VTArrrgh!
10-21-2013 01:45 PM
Daytona
12-20-2011 07:03 PM
jeephawk
08-31-2011 07:53 PM
Starbucks Fueled
03-19-2009 08:42 AM
Vega (streetfighter)
01-12-2009 01:46 PM
Quick Reply: Surging at cruising throttle
