SuperHawk Forum
-   -   Side stand woes (https://www.superhawkforum.com/forums/general-discussion-30/side-stand-woes-28649/)
jeremyabbott 06-26-2012 07:00 PM
Side stand woes
Hey all, I am not sure what the PO did when he had this bike but the side stand is tweaked and curved the bike leans over a bit more than I would like and is a bit scary on a slope. Anyone know a good place to get a replacement side stand?
Wolverine 06-26-2012 07:03 PM
There's tons on fleabay! Or a cbr1k swap.
captainchaos 06-26-2012 07:35 PM
I think I have a good one from the bike I recently parted out. I'll double check for you.
smokinjoe73 06-26-2012 07:47 PM
Not sure why he would heat and bend it. If you do stand flips you can bend it. I used to do them all the time before I added a plate to extend the stand for my penske shock.
Stand flip is balancing the whole bike on the stand and rotating it 180*.
jeremyabbott 06-26-2012 08:05 PM
I have actually done stand flips quite a few times with it but it was already bent before that. And thank you Captain.
HRCA#1 06-27-2012 07:31 AM
I saw on a thread that someone used a CBR1000 side stand cause it was longer by @1 inch but I'm not sure of the year or whether it was a F or RR model, anyone know?
GTS 06-27-2012 10:27 AM
Just bend it back. Has the rear of your bike been raised to improve handling? That would exacerbate the issue, or just cause it to lean more than usual to begin with.
Tweety 06-27-2012 11:48 AM
CBR 1000RR 04-07 works nicely... Newer may work, but I haven't tried it...
HRCA#1 06-27-2012 11:55 AM
Thanks Tweety I figured it was you or Hawk8451 or at least one of you would know.
red02vtr 06-28-2012 07:17 AM
I'd be interested to know if its a direct bolt on and if its worth the switch.
My hawk leans way over on its stand, tends to eat right through asphalt parking lots unless I bring a little plastic piece.
