Shifter issue.
I am looking for an aftermarket shifter to replace my broken stock shifter. I priced an OEM shifter at the local Honda shop and they want like $95 plus tax for it which is a little pricey in my opinion. If anyone knows where I could get one for a decent price I'd be much appreciative.
If you are looking for a new one try bikebandit.com
With a previous bike that I rebuilt I had lots of luck with different breaker yards. Motocyclist magazine usually has a add or two in the back that list some of these. |
:lol:Do you need the whole shifter assembly or just the shifter itself
Parts found with Part Number: 24705-MBB-000DescriptionPEDAL, GEARSHIFTPrice$68.51 Thats from Ronayers.com Service honda may be a bit less. Other then full rear sets, i've not seen an aftermarket shifter
Originally Posted by Aviationboy
(Post 170858)
(Post 170858)
The piece that is actually broke is the kick shift, the lingage and everything else is fine. I actually drilled a hole in it and tightened a bolt up and glued the original rubber back on but it seems like it is fairly weak. It seems to flex when I work it back and forth. I've also had someone telling me they saw an aftermaket shift lever for arund $40 but he doesn't know were it was.
