Shift Points/Normal RPM's
I am new to the Sport Bike World. I recently picked up a 98 Superhawk but my usual ride is a VTX 1800. My question is what are your usual shift points and what rpm range do you run in on a normal basis. I am used to the cruiser sound so the bike always sounds to me like it is going to explode. I think I am running at too low an RPM but dont want to push it too hard just in case.
Thanks for the Help Hawk I Fan |
I usually shift between 4-6k rpm. Much higher when I'm pushing it in the canyon. :)
Let's see some pictures!! |
I shift around 5K for communting to work, but shifting around 4K will get you better MPG.
For sporting rides around 8K. YMMV |
I have gone from a cruiser to a sport bike and you are right, it feels like you are over-revving it all the time.
But sportbikes (especially 4 cyl) are designed for higher revving of the engine, so don't worry about it. My personal riding style: relaxed and smooth. For those purposes, I shift between 4-5k rpm which gives me a nice comfy ride (which again, compared to your VTX1800 that is quite high). In twisties, I also like to short shift and keep the rpms lower. I don't see how a choppier throttle (at higher rpms like 8k ) can make a smooth ride... especially on the hawk where the torque band is so wide. so, find where you are comfortable with and do just that. |
Re: Shift Points/Normal RPM's
I did the opposite and rode a buddy's VTX1800. Damn was that an odd feeling.... I was bouncing off the rev limiter at 20mph!!
You have to control the choppyness (if that's a word) with smoother throttle control. You just don't slam the throttle closed unless you want to use the engine braking, to setup for the curves.
Originally Posted by faz";p="
(Post 1955)
Thanks for the info. I guess it is just going to take some getting used to.
Chris |
Originally Posted by john2kvtr";p="
(Post 1978)
(Post 1955)
so, find where you are comfortable with and do just that. I guess once I start riding track I will be more open to pushing the revvs up, but for street speeds, 5k-6k rpm works fine for my relaxed riding style. :) |
