SuperHawk Forum
-   -   Radiator rust (https://www.superhawkforum.com/forums/general-discussion-30/radiator-rust-33390/)
whatthefnck Jul 26, 2015 12:21 PM
Radiator rust
1 Attachment(s)
I'm swapping from broken radiator to one I purchased used from someone else. Looks like a rust film thruout. Is this ok? Or should I not use it? Possible to clean out? Image attached to view and compare. If any idea, let me know.
whatthefnck Jul 28, 2015 10:06 PM
..as of right now 86 views and nada. No one know anything? Cmon now guys
scottiemann Jul 28, 2015 10:11 PM
I would clean it. I'm pretty sure most radiator flushing chemicals are meant to clean out rust so I would drop it in a 5 gallon bucket mixed with hot water and rad flush and let it sit for a while maybe a day or 2(but keep an eye on it) and see if it does anything then flush it out with your garden hose...
kenmoore Jul 29, 2015 02:42 AM
Take it to a radiator service and have them flush it .
You way have to re paint it but that will solve the problem.
CrankenFine Jul 29, 2015 03:02 AM
+1 & they can pressure test it while it's there.
Hangfly Jul 29, 2015 08:22 AM
It doesnt look bad enough to foul things up or prevent good heat exchange.
Run it and change the coolant after a thousand miles.
Thanks for posting. It makes me realize I need to flush the cooling systems on my vehicles .
Pidge Jul 30, 2015 05:12 AM
Fill it up with a hot solution of 1 part white vinegar and 2 parts water. Let it site and then flush with water.
Wolverine Jul 30, 2015 06:28 AM
I agree w/ scottie.
whatthefnck Apr 21, 2016 09:14 PM
Originally Posted by Wolverine (Post 388956)
I agree w/ scottie.
E.Marquez Apr 22, 2016 10:23 AM
I agree with all of the above :o
Clean and go.
