question......
I am new to the superhawk / sportbike world.
Want to learn to wheelie my bike , but I do not wish to drop it. Saw on e-bay a vidio on wheelies on a vtr. Has anyone seen this ? I am sure many of the vet's , are rolling laughing at this squidish request, however , money is tight in this household so........ Any serious information is very much appriciated , and I humble myself to the jokesters that want to chime in. Thanks L-man out:???: |
Wheelie
Check out this site and see if it helps. Maybe get some input from some of you vets out there.
http://bikerpunks.com/page/35/ |
that is a cool vid, I might even go try it, seems easy enough....dum du dum dum.....lol....nah, maybe not...
heard about a wheelie bar very similar to a small antenna that comes off the swingarm and when it gets bent up to far it shuts the motor power . cant remember the sight but try a search?
Wheelies with a Superhawk are pretty easy. You should be able to hoist it up with only a little effort.
From a dead stop - Revs up, clutch out. Bring up the revs a little more each time. While in motion (1st or 2nd gear) - Roll off throttle, pull clutch in, gas up, clutch out. You may need to "bounce" the handlebars to get a little more lift. With very little practice, I was bringing up 1-foot wheelies. Not very exciting stuff, but I feel safer with two wheels on the ground. ;) |
I don't know if this is an option for you or not but if you want to learn how to wheelie find a dirt bike! The only way to learn is practice and the only way to practice is to do it and probably fall a few times.:???: Just my opinion but pavement hurts!!
Really if you want to do it just get rolling 1st gear about 2500-3500 rpm let off and whack the throttle, the bike will do the rest.
Originally Posted by superhawk22
(Post 40293)
In the fall and spring when the air is clean and cool i can get mine to pull a third gear wheelie with a little clutch slip running arounf 5.5-6 k rpm, but in the summer she aint going solo in third unless you shift into third while on a 2nd gear wheelie. For me 2nd gear is the best gear to wheelie in, just a slight slip of the clutch running around 5k and the front is skyward. A good suggestion is if you plan to do a lot of these i would upgrade the shitty ball type bearings in the triple tree with some goos aftermarker roller bearings. |
Reply
Thanx's guys
L-man out |
Originally Posted by Thumper
(Post 40298)
hummmm I don't ever recall having to roll off and back on hard to get the SuperChicked to go solo.
Originally Posted by marmaladeboy
(Post 40291)
Or at the track coming out of a corner making it LOOK like an accident. :lol:
| All times are GMT -7. The time now is 06:47 AM. |
