Prospective Superhawk owner with questions
I saw my first Superhawk at the San Mateo motorcycle show in 1997. I was struck by the minimalist appearance and how much it reminded me of a hunting wasp. I had a poster of one on my office corkboard for several years. Now I'm finally considering buying one. (Well, actually, there's two I'm looking at, a black '99 and a red '01.) But ... I have a few questions I'd like to pose to people with plenty of Superhawk experience.
To start with, I have artificial knees (I got left-turned 16 years ago, totalling my customized '91 VFR750F3 under me), and I've never regained full range of motion. I can sit on a Superhawk with stock pegs, but it's not entirely comfortable. It's a strain on my knees. I've found a thread from a couple of years back that mentioned Superhawk adjustable rearsets, in particular the Danmoto or the Cycle Pirates 360s. Has anyone used these or any different rearsets to move the Superhawk's footpegs down and forward, instead of up and back, to open up the knee angle a bit? Is there a specific set folks recommend? I've also seen the Gilles Tooling, but I'd prefer not to be spending that kind of money just on footpegs. Do the rear brake lever and shifter also need to be moved in this case? Speaking of shifting ... I have between ten and fifteen degrees range of motion in my left ankle. Shifting on the last bike I had, a CBR929RR, was possible but very tiring, because I basically had to shift from the hip. (And after my damaged knees gave out and had to be replaced, I couldn't ride it at all any more.) So I'm giving really, really serious thought to a power shifter in the long term. Does anyone have any recommendation for power shifters that work well on the Superhawk? When I was considering one for my CBR929RR, I was looking at Translogic, but I don't know what else is out there — and honestly, I'd prefer not to spend almost $900 on one if I can find a less expensive one that still works well. Any advice here? Finally, what is the wisdom of the knowledgeable when it comes to maximizing the light output of the headlight? I'm a big believer in lots of bright white light on the road at night, but I don't want to blind oncoming traffic. I'm also a big believer in LEDs, but I'm not sure they're quite there yet when it comes to replacing halogen headlamp bulbs. |
Expanding a little on my last question, I seem to have basically four headlight options:
(Yes, I try to do as much as possible of my research before I jump. Why do you ask...? ;) ) |
#1 is to get the Eastern Beaver headlight harness to get a feed directly from the battery. That will make your stock light SUPER BRIGHT.
I personally would try that first before doing anything else, because it's such a drastic difference. James |
You could always spend the money on a HID retrofit from The Retrofit Source Inc (an actual retrofit, not just the "HID" light in the wrong headlight housing)
Do a search here. A lot of info here. I just did a retrofit myself and couldn't believe how easy it was! |
(Post 389961)
Originally Posted by CruxGNZ
(Post 389965)
2 Attachment(s)
So, your headlight has a projector inside the housing, like this? If not, you just have a HID bulb in a housing that is not made for that type, like you mentioned.
Attachment 21894 Attachment 21895 |
(Post 389969)
I honestly don't really know where to start with a full retrofit conversion like this one. I'd need to do a lot more research before taking that leap. Is it street legal? (...on further thought, I realize the answer to that question may vary state by state.) |
Oh, and by the way.Consider that "prospective Superhawk owner" changed to "impending Superhawk owner". I'm buying the '01. :D
Crux, what are the specs on the stage 1 did you end up using ?
Jury is still out on LED conversions. I have given up for the time being.
Too bad you're ending up with a red SH. You know they are the second fastest color? |
