SuperHawk Forum
-   -   Largest Carb on a production bike? (https://www.superhawkforum.com/forums/general-discussion-30/largest-carb-production-bike-19175/)
fuzzuki Jun 15, 2009 08:20 PM
I think I remember reading that the VTR has the largest carbs ever produced on a production bike.
Was that true?
And if so, is it still true?
What size are they? 48mm Flat slike Mikuni's????
mikstr Jun 15, 2009 08:23 PM
I beleive that is correct, but they are 48 mm CV carbs
RK1 Jun 15, 2009 08:35 PM
They're Keihins.
skokievtr Jun 15, 2009 09:28 PM
If you have a long
beard or let little kids near the carbs with the air box cover off, don't let either get too close if its running...
autoteach Jun 15, 2009 09:41 PM
I remember telling my summer boss that they were "BIG" and he brushed it off. He ran a shifter cart with a 44 and has dual 40's on his 1980 srx440. When I was doing carb work he looked at them and said, "HOLY COW, you weren't lying"
maverick Jun 15, 2009 10:14 PM
I've only ever heard them described as the largest honda has ever put on a bike but I've never heard of any that are bigger...
VTRsurfer Jun 15, 2009 11:46 PM
They're 48 mm.
The Aprilia RSV4 has FOUR 48 mm throttle bodies. And the Ducati Streetfighter S Has 60 mm elliptical throttle bodies.
fuzzuki Jun 16, 2009 03:28 AM
Ok. Those are big throttle bodies.
But that's still Fuel injected. I'm talking actual carbs here.
Originally Posted by VTRsurfer (Post 222610)
They're 48 mm.
RK1 They're Keihins.
mikstr I beleive that is correct, but they are 48 mm CV carbs
Yes, Keihins, but they're Flat Slide CV's.
mikstr Jun 16, 2009 04:53 AM
The SP-2 had 62 mm throttle bodies (SP-1 had 54 mm). For carbs, a few sleds (notably the 95-96 Ski-Doo Mach 1 and MXZ 670 HO) had 44 mm round-slide (Mikuni VM) carbs.
REDVTR1000 Jun 16, 2009 05:31 AM
i did a little research and i cannot find another production bike with a 48mm carb. does not mean they are not out there but google doesn't know of one. i did find an article saying that 48mm is about the practical limit for motorcycles.
mikstr Jun 16, 2009 05:35 AM
A 48 mm non-CV carb, now THAT would be one honkin` carb!!!!
steve.g Jun 16, 2009 06:20 AM
The new V Max has 4x 48mm throttle bodies ...
Zedicus Jun 16, 2009 06:52 AM
cv carbs arent directly comparable to other types, lik FCR or something. but yes 48mm is still big. i know of carbs that are larger, but not stock on production vehicles. the 42mm is largest non-cv carb on production vehicle i know of, and i would bet it performs better then our 48mm cv.
BTW Honda owns a controlling share in Keihin so they dont use Mik carbs very often. it does happen, just not often. and our 48mm's are keihin.
nothing Jun 16, 2009 07:04 AM
and it sure feels like it!
mikstr Jun 16, 2009 07:04 AM
As mentioned earlier, a few snowmobiles came with 44s (if you consider those vehicles...). I also recall an aftermarket snowmobile parts manufacturer building them up to 52 mm (for large-displacement custom two-stroke snowmobile engines). Now that is a big-ass carb!
mikstr Jun 16, 2009 07:06 AM
You have to remember that a 48 mm throttle body wil not flow as much air as a 48 mm slide carb due to the presence (and turbulence) of the butterfly (and many new bikes even have two per throttle body). I always wondered why they never built slide-type FI systems (no butterfly to screw with airflow)...
