Just installed Ape cct, Very Happy!
Old Jul 31, 2010 | 02:58 PM
motogomojo's Avatar
motogomojo is on a distinguished road
At about 18,000 Miles on my 2002 , there developed a noise in my front cylinder that was quite concerning and growing in intensity each week. Thanks to all the info on this board ,I assumed it was a stock cct going.
Ordered in some Ape Manual cct......and WOW! My motor sounds like it just came off the assembly line.Purrs like a kitten and no more rattle of death.
Just wanted to thank everyone on here for all of the instructions on how to do this procedure.
I send much good Karma your way!
Old Jul 31, 2010 | 03:42 PM
motogomojo's Avatar
On a side note...... my final adjustment for the Apes were finger tight, (as tight as possible with oily fingers) minus 1/2 a turn.
At this tension,it appeared to be within Ape's instructions of 1/4" to 3/8" deflection in the chain between the cams.
I am curious as to others who have installed manuals.Does this sound similar to your final adjustments?
TIA
Old Jul 31, 2010 | 05:08 PM
thetophatflash's Avatar
Did my final by sound.
Old Aug 1, 2010 | 05:43 AM
nothing's Avatar
ride it out
mine i finger tightened then just a little bit with a wrench, and that was perfectly silent
Old Aug 1, 2010 | 09:47 AM
jztam's Avatar
jztam is on a distinguished road
CCT... stripped the 10mm allen cap plug on alternator cover
I let the penetrating oil soak in overnight, tapped it with a small hammer, re-oiled it and let it sit for an hour. Now I've half stripped the 10mm female hex cap on the alternator cover. Should I even bother trying to save the cap, or just start carving it up with a Dremel cutoff wheel, and buy a new one?
Jordan
Old Aug 1, 2010 | 10:17 AM
Jordan
https://www.superhawkforum.com/forum...0&postcount=14
Tofazfou
Mar 3, 2014 02:49 PM
Crashrat
Oct 11, 2012 08:25 PM
Matt_Hawk
Nov 27, 2011 07:31 AM
AMF Racing
Aug 29, 2009 08:20 PM
AZZKIKER
Aug 13, 2004 05:32 AM
