Installed K&N air filter, problems???
Old Apr 11, 2005 | 07:59 AM
superbling's Avatar
Re: Installed K&N air filter, problems???
It's been a while since I've read Dyno-Jet's instructions and then it was of only passing interest since I didn't have a K&N filter in my setup but IIRC adding the filter requires a bump up on the jets if you coming from a stock filter and aftermarket pipes.
But where are the flat spots? Their trouble shooting sections says a common mistake is trying to tune with jets when it's the needles. I'd suggest going to 5 first.
Old Apr 11, 2005 | 07:30 PM
superbling's Avatar
Do a search for the radio shack washer mod. I believe it's around .020 inches or so but I could be very wrong so don't go by that.
If you don't have any washers below the clips right now, you might want to try raising the needles to the 6th slot instead. The washer mod is intended for stock needles.
yruyur
Apr 4, 2009 04:52 PM
selztoad
Feb 16, 2008 07:29 PM
filter_jam
Apr 20, 2007 07:05 AM
mkimber
Mar 30, 2007 05:49 PM
