I don't often work, upgrade my own bike..
5 Attachment(s)
I don't often work, upgrade my own bike, mostly someone else's
But today it's mine All new paint, all plastics, tank, new graphics. FZ1 Fuse block install Ceramic coated headers New side stand to get rid of the gangster lean due to suspension build that raised the rear 10mm Mirror extenders so I can see something in them other then my elbows Digital clocks to be molded into the dash Some assembly required https://www.superhawkforum.com/forum...1&d=1432249849 Fresh paint, Italian Red and graphics https://www.superhawkforum.com/forum...1&d=1432249901 Headers ceramic coated by Polydyne in Texas .. DO NOT RECOMMEND THIS COMPANY .... Not even a little. Not happy with the customer service of the shop that did the coating but the work seems ok https://www.superhawkforum.com/forum...1&d=1432249961 Nice new side stand,,, some mod required as it has a different bend then the straight OEM one.. But it will be nice to not have the bike leaning over so far. https://www.superhawkforum.com/forum...1&d=1432250036 Another FZ1 Fuseblock install.. this is about a dozen now I've done.. I reallllllly like this product... https://www.superhawkforum.com/forum...1&d=1432250086 |
looking good brotha!!!
need details on that fz1 fuse block as you probably know I'm rewiring the entire bike and am in need... |
3 Attachment(s)
The dash on the 1998 is a bit dated. Though mine has a brand new cover just a few months ago so looks fresh at least...... having no clock thought gets old.. I tried a simple solution of using a digital watch., but found finding the buttons at night with gloves on not really workable, and the digits size is a bit small.
So ordered up two different 12v digital clocks, one is red led in a black housing. The other blue LED in a clear housing. https://www.superhawkforum.com/forum...1&d=1432250222 While I have nice looking elbows I have grown tired of seeing only them in my mirrors. There is a chap in the UK that makes extenders for this bike so i had him send me a set. https://www.superhawkforum.com/forum...1&d=1432250259 Side stand on last night, removed the bracket and spring, tossed in the sonic tank for a bit while I worked on the headers,,, then installed the stand... |
3 Attachment(s)
Headers went on as do most after market exhaust systems using other then supplied in designed hangers and different band headers (OEM ceramic coated in this case with Leo Vince carbon cans, stainless steel high mount link pipes, mounted in a mid high location so they run parallel to the tail piece body line.
https://www.superhawkforum.com/forum...1&d=1432251229 Hangers are a temp deal... one has a crack do to previous owners bending them to fit how they wanted...and for me, the hold the can too far forward in both looks and lack rigid attachment. https://www.superhawkforum.com/forum...1&d=1432251261 https://www.superhawkforum.com/forum...1&d=1432251492 Im making some trellis style mounts that will drop down from the sub frame and attach to the can just about mid way front to rear.. using 8mm thin wall co-molly tubing for the legs of the mount and a 10mm short section for the attachment point of the hanger to can.. |
Looking good :)
(Post 386392)
need details on that fz1 fuse block. |
(Post 386392)
need details on that fz1 fuse block as you probably know I'm rewiring the entire bike and am in need... http://www.fuzeblocks.com/images/thumbnails/015_tn.jpg I've used the PC8 from Eastern Beaver and this one, like the FZ1 better. more compact install, all circuits are switch/non switched capable. More compact. But there is a down side if it apply to your needs.. the FZ1 is smaller, more compact and only has 6 circuits,.. and limited somewhat in wattage capacity. From the company FAQ How much current can the FZ-1 handle? This isn't as straight forward as you might think. The FZ-1 has two separate current paths. One is for constant power and the other goes through the relay for switched power. Each circuit can handle up to 10A (120W). The total amperage used via the relay (switched power) should not exceed 30A (360W). The total amperage on the constant side should not exceed 30A (360W). The total amperage for the entire FZ-1 should not exceed 30A (360W). I've spoken to the small company owner / designer after I was introduced to this fuse block..and before I started installing them on customers bikes. We spoke about the realistic durability of the uni in rugged use, high heat, dusty environment, it's "weather resistance" for use in wet climes or occasional torrential downpour. It needs to be mounted securely and not be bouncing around... it has to be mounted in a location that it does not get submerged, or directly sprayed with water (so under the seat, behind the fairing, under the fuel tank.) We chatted about the choice of a board mounted relay vice plugged replaceable.. 1: they simple chose a great quality relay for this application... and second, in R&D testing and now years of actual use, they are not seeing any failures note worth.. so the choice just works. IF the relay should fail, the rider can just ,move a fuse position and power the needed device in non switched mode till they get home. The relay can be de-soldiered and replaced as it is a commonly available item and the replacement procedures common as well fro anyone that works with a soldiering iron and boards mounted components/. |
I looked at this unit on their website after you posted about a week or two ago. It's a nice, flexible unit and I plan on using it in the future as well. Thanks for the info, E.
1 Attachment(s)
I don't often work, but when I do, it's on a Superhawk.
Attachment 22027 Nice shop you have there! Many of us would love access to such a place. Keep up the cool upgrades. |
Is the ceramic coating inside and out of the headers? Did they decoke em to remove the carbon deposits?
Originally Posted by Wicky
(Post 386424)
Though inside ceramic coating is not what most think it is.. Not the same even coating as outside unless you are having a very high tech and expensive process done (by expansive consider it 5 or more times what you were quoted for the "standard" job). Inside coating uses a LOT of ceramic materiel with a ton of waste.. cut open headers from the top brand name ceramic coaters and be surprised at what you find after you were given claims of "Coated inside and out".. What you will find is the first few inches of inside coated... and thats all. . |
I appreciate the info, gonna have to check that out and get to ordering because I will be wiring hopefully in the next couple weeks or so...
fellow texan here, starting a big rebuild soon myself... may be chasing you down for pointers. looks good.
1 Attachment(s)
Went looking for a tool
Hunted for ten minutes Decided enough was enough time For a build and reorganization Made another stand for my top box added two shelves for "cased" tools and added a single drawer full width 5" deep mid chest https://www.superhawkforum.com/forum...1&d=1432733914 Never enough room for tools... but it'll do for tonight. Finished tool chest stand, recognized tools...cleaned shop.. ready to start again in the morning. |
Yea I have to do the same thing... been working on my bike nonstop in all my free time and not doing a damn bit of cleaning (besides picking up the empties :p) place is a mess and Im wasting too much time looking for things...
Shop looks great BTW |
1 Attachment(s)
Fuse block install done
https://www.superhawkforum.com/forum...1&d=1432819278 |
Done (for now, kind of, maybe)
1 Attachment(s)
https://www.superhawkforum.com/forum...1&d=1432863610
Done, almost, kind of, for now :rolleyes: The cheap digital clock was a failure one arrived dead, the other died in less than an hour on the road. Still like the idea so will search out something else to try. Still need to build the exhaust hangers ..have the smaller chromoly tubing I'm going to use... but the 10mm OD stuff did not show up yet.:mad: Side stand needed some additional MOD as it was hitting the ex mid pipe in the up position, bit of weld, then dressed up and shot with some black enamel fixed that up. Looking to add a carbon fiber "dash" grafted onto the OEM dash cover held in place with the three mounting bolts used now. Then will flush mount the clock, gear position selector and Koso voltage gauge. |
Pretty sweet bike ya got there Erik. I love the subtle mods :)
Do you have a link or contact info for the mirror extenders?
Mike |
Originally Posted by motomikec
(Post 387640)
Mike |
I totally dig that you went through everything for yourself, it's so easy to say that you're going to "Get to that", and next thing you know, you just don't have enogh time in the day...
It looks really, REALLY good E..! |
