SuperHawk Forum
-   -   How do I drain the carbs? (https://www.superhawkforum.com/forums/general-discussion-30/how-do-i-drain-carbs-21863/)
CentralCoaster Mar 16, 2010 12:04 PM
I need to drain old gas out of my carbs.
The bike doesn't run, so running it dry isn't an option.:mad:
poppazuti Mar 16, 2010 12:13 PM
take a long flat blade screwdriver and open the drain on the bottom of the bowls. It's a little nipple on the very bottom of the carbs. Right side is easy to get too, the left side sits a little further inboard.
RK1 Mar 16, 2010 12:21 PM
If you don't want to make a mess, fit some tube/hose over the nipple on the underside of each float bowl and route it into a container on the floor/ground. Open up the screw on the lower outboard of each float bowl.
8541Hawk Mar 16, 2010 12:22 PM
This is correct though a bit confusing. The drain screw is on the side of the float bowl and it drains out of the nipple on the bottom.
poppazuti Mar 16, 2010 12:26 PM
Agreed...didn't think to mention that. Mine is having a fuel feed issue so I didn't have a tremendous amount of fuel in the bowls, but it was enough to still make a mess. Also worth mention is the screw only needs to be cracked open a few turns, not completely removed.
zmaniv Mar 16, 2010 02:18 PM
Hey Kevin if you want to we can find a way to get your bike to Mike at Full Throttle and work on it there.
peterpanic Mar 16, 2010 02:42 PM
Turn bike upside down? sorry, had to.
VTRsurfer Mar 16, 2010 02:53 PM
+1
I use a 3/16" wide by 8" long screwdriver and extra long "stork" needle nose pliers to slip a hose on the drain nipple.
If your gas is that old, you probably need to clean the carbs too. Since new my bike has never gone more than 7 days or so without being ridden. Last Saturday I started running on one cylinder, limped home and found #2 was dead. Spark was good, so I pulled the carbs (a lot of fun:rolleyes:). The slow jet in #2 carb was completely plugged. I had to soak it in carb spray for about 30 minutes to clean it out completely. Then blew everything out with carb spray and compressed air.
I'm looking for some small membrane type filters that will fit under the tank.
CentralCoaster Mar 17, 2010 08:10 PM
Don't scare me like that. My other bike is already apart for the same reason, previous owner didn't ride it, carbs were completely disgusting. Sad because I sold it to him in perfect working order a year prior. At least I got a good deal buying it back from him.
CentralCoaster Mar 17, 2010 09:33 PM
Thanks! I just drained it out onto the floor. Didn't feel like cutting my hands up trying to get a drain hose on there. It was pretty obvious when looking at it, I just posted from work so I didn't have the bike in front of me.
VTRsurfer Mar 17, 2010 09:41 PM
That works...just don't light a cigarette immediately after draining.:eek:
RK1 Mar 17, 2010 10:11 PM
I use a pair of medical forceps to slip tubing over the drain. I imagine needle nose pliers or vice grip would work. Otherwise you can do it outside and use a hose to rinse the gas off the bike and ground. I like to drain to a container so I can check for water, gunk, debris etc.
VTRsurfer Mar 17, 2010 10:33 PM
The "stork" needle nose pliers I mentioned were first sold by Snap-on about 25 years ago. They're about 12" long to reach into very narrow deep openings. I bought a pair of Chinese knock-offs last year from Kragen for about 12 bucks. The first time I used them was to drain my carbs. It took no time at all to snake a length of vacuum hose in there and push it up onto the drain nipple. A good addition to your toolbox.
I'm aware of other uses for medical forceps ;) from my younger days.
RK1 Mar 17, 2010 11:30 PM
Me too. Before I discovered the value of a cheap corn cob pipe and a 2"X2" square of Reynolds wrap poked with a finishing nail or sewing needle!
I bought the forceps at the Del Mar gun show in 1995 for $2. Also great for slipping tube over the front cylinder vacuum nipple when syncing the carbs and for removing splinters from my hands. Just might be the best two bucks I ever spent.
CentralCoaster Mar 18, 2010 05:26 PM
I prefer to fill the garage with gas fumes, close the door, and then relight my water heater pilot.
