SuperHawk Forum
-   -   headlight help (https://www.superhawkforum.com/forums/general-discussion-30/headlight-help-13300/)
kostavtr Nov 30, 2007 06:39 PM
headlight help
hello does anyone know if there is anyway to adjust the headlights because my shine straight down it seems...thanks for the help
nuhawk Nov 30, 2007 07:28 PM
make sure the bulb is seated into the headlight module securely.
drew_c14 Nov 30, 2007 08:27 PM
ride around with the front tire about six inches in the air
Hotbrakes Dec 1, 2007 03:28 AM
Mine always seem to point up to the trees for some reason. I'm thinking about getting a Bat signal for it. lol
There are 2 10mm bolts behind the dash. One in the top left corner and one in the bottom right (or vice versa). If you are adjusting to move the headlight up and down, you must adjust both cause adjusting one will move the light from side to side as well as up and down. Adjusting the low beam too high is nice cause it sheds light on a lot off stuff but then the high beam will shoot right over everything so find a happy medium.
reaper Dec 1, 2007 07:29 AM
Make sure the light is seated properly before you push the wire clip back into place, that might be the problem.
nuhawk Dec 1, 2007 02:13 PM
I thought I said that :crackup:
KC-10ENG Dec 1, 2007 04:28 PM
Oh and by the way if you really need to get access to the bulb and stuff just pull the fairings off in one piece and take a look at it.
Dennis
