front wheel interchangability?
can anyone advise me on what other front wheels are compatable with my VTR1000F using all other stock VTR parts? I need a wheel to replace my bent stocker and cannot find a superhawk wheel right now so anything like an F4 or F3 wheel would be fine as long as everything bolts up. RC51? 929? etc.....
f4, f3, vfr800, nc30, cbr900,will bolt right up but if im wrong some one here will def put you right and me!!!!
thanks, that helps. I will probably avoid 900RR wheels because they are the oddball 16 inch size but I should be able to find something now with all these other bikes to choose from. can anybody confirm the VFR/F3/F4 wheel fit?
I think the vfr 800 wheel upto year 2000 pre vtec if thats any help, i'm not sure if the later will fit not very clued up on the vfr800 series.Good luck
Originally Posted by whipit
(Post 38882)
The F4/F4i has a different brake rotor mount so you would: 1) have to use F4 rotors but only if 2) rotors are the same size (diameter) and width as the VTR. |
