Are front turn signals also running lights?
Old Mar 6, 2005 | 06:05 PM
NOrrTH's Avatar
Re: Are front turn signals also running lights?
My '98 they're running lights as well (dual filament), rear are single filament. Can't imagine why they would change this in '02
Old Mar 6, 2005 | 07:09 PM
divingindaytona's Avatar
Remember stock is BAD!
I have an 02 as well. Stock the front are running lights as well as turn signals. The rears are only on when the turnsignal is on.
Old Mar 6, 2005 | 09:39 PM
superbling's Avatar
Yes, hondas run the fronts as running lights, hence the extra power wire and dual filament bulbs. Most other makes and aftermarkets don't do this and I don't know why except for $ reasons.
That's why I changed the previous owner's flush mounts back to OEM. I prefer the running lights.
Old Mar 14, 2007 | 03:11 PM
nova_scotian_996's Avatar
nova_scotian_996 is on a distinguished road
Can you get Flushmount LED's that are geared up the same as a dual filament bulb? I want the safety of the running lights but the sleek design of the flush mounts. I ordered some off of ebay, but the flushmounts are two wire and the instructions state that the running lights will not work..
Any help from the Gurus on here would be great.....
Old Mar 14, 2007 | 03:36 PM
As discussed on the phone, www.vfxkits.com has a great setup. They act as running lights with variable intensity and also get the flash rate correct. I've had nothing but good luck with them.
Edit: It's the Running Light FX kit that you're looking for. Forgot to mention that they have 17 different flash modes too!
Old Mar 14, 2007 | 03:41 PM
cool I will call tomorrow....thanks again for the help
Old Apr 1, 2007 | 06:04 AM
xecutech's Avatar
xecutech is on a distinguished road
The only Honda ones they carry are for the cbr's. Will these work on the sh?
Also, will they cover the holes completly?
Old Apr 5, 2007 | 07:39 AM
xecutech's Avatar
Well, will they?
Old Apr 5, 2007 | 08:00 AM
Are you talking about stock? Be more specific.
Old Apr 5, 2007 | 09:04 AM
xecutech's Avatar
The ones from vfxkits.com. I went to their site and it didn't show one for the superhawk, but had the cbr's. I think there were 3 models, so I didn't know which one to go with.
Also, do any of you know of any other flush mount led lgihts that will fill the stock hole?
Old Apr 5, 2007 | 09:18 AM
I actually have not even looked at the lights that VFX sells. I just use their flash equalizer and running light kits. I have Lockhart Phillips Type 4 -large on mine. There's a fairly recent thread on this somewhere....
https://www.superhawkforum.com/forum...melt#post45098
Old Apr 5, 2007 | 09:32 AM
xecutech's Avatar
Thank you for your help. I think I want a flushmount with leds instead, but may opt for these for now. Again, thank you for the reply.
Old Apr 8, 2007 | 05:29 PM
102dals's Avatar
Please keep the list updated with what you buy, and how well it works. Take pics as you go, with the mod, so they can be posted also.
Thanks
Old Apr 8, 2007 | 07:37 PM
vtrlvr's Avatar
vtrlvr is on a distinguished road
I want the type 4 also, but want them in smoke leds and those only come in small and medium. I guess i will buy them and see if they cover my stock holes.
Old Apr 9, 2007 | 07:33 AM
xecutech's Avatar
Don't the make led bulb replacements and couldn't that be used with the LP #4's?
Old Apr 9, 2007 | 11:25 AM
I changed to the 3-wire Lockhart Phillips Type 3 front ts/rl and installed the oem ft ts in the rear and t'd in and ran the rr feed to the rr so I have rl ft & rr.
Much safer along with my red neon license plate surround tied into the brake circuit and twin 55w halogen driving lights. My radar/laser detector could also be considered a safety mod.
Old Apr 9, 2007 | 06:52 PM
vtrlvr's Avatar
Good idea xecutech i will look into to that.
Old Apr 12, 2007 | 10:06 PM
102dals's Avatar
I bought a set of flushmount LEDs off Ebay, and they're too small for the stock holes (fall right through). They also don't have running lights. I'd actually added dual filament OEM signals to my tail signals, until I took them off to mount my high-mount pipes. I'm searching to find LED fronts that fit well (flush).
rafbo
Jan 3, 2019 02:38 PM
jon1475
Sep 2, 2013 06:34 AM
johnclopp85
May 13, 2009 07:20 AM
