SuperHawk Forum
-   -   Fixing the mirror rattle (https://www.superhawkforum.com/forums/general-discussion-30/fixing-mirror-rattle-12454/)
Otto Man Aug 24, 2007 06:48 PM
My drivers side mirror rattles like you wouldn't believe when I first start up the 'hawk, and most of the time while sitting at redlights. Sometimes it's not too bad, but other times, it sounds like the dreaded death rattle of an engine with no oil in it. Just push on the mirror alittle bit...and it quits. Does anyone elses do this? It's only the one mirror too.
luckyluke Sep 3, 2007 02:27 PM
Yesssssss! My '98 Fire Storm does the same sometimes and it freaked me out the first few times I heard it. It seems to go away and then come back some other times.
I'm thinking of putting a little clear silicone with a toothpick or something in the space between the mirror and it's frame; then cleaning it with a razor blade when it cures.
falcondrvr Sep 8, 2007 07:17 AM
Mine used to but that's because one of the welds broke loose on the stalk that the mirror is mounted to.
Grab the mirror and look under your fairing. shake the mirror around a little and see what you've got. If it's broken, you'll see what I mean right away unless it's a problem that's just starting. Mine took about 1 year before it got bad enough that I took the whole thing to get welded up again.
J
Otto Man Sep 8, 2007 11:59 AM
That's what my plan of attack is gonna be. I'll let you know how it works out. :cool:
midijunky Sep 8, 2007 12:56 PM
Possibly could it be the little weight thing inside the fairing stay? I think they call it a dynamic weight damper or something close to that?
