Engine support bolts need to be torqued?
Old Feb 27, 2013 | 06:04 PM
19superchicken98's Avatar
19superchicken98 is on a distinguished road
I installed frame sliders and was wondering if the engine support bolt need to be evenly torqued?
Old Feb 27, 2013 | 06:16 PM
yep
Old Feb 27, 2013 | 06:17 PM
Originally Posted by 7moore7
yep
What torque do they need to be at? I tried reading through te manual but it makes no sense to me lol
Old Feb 27, 2013 | 06:47 PM
CrankenFine's Avatar
https://www.superhawkforum.com/forum...-torque-13880/
29 ft/lb
Old Feb 28, 2013 | 04:48 AM
cybercarl's Avatar
Here you go I have done a write up on engine mounting over in the UK. There's also a downloadable copy in a PDF format.
www.vtr1000.org • View topic - Engine Mounting Bolt Sequence and Specified Torques
Old Feb 28, 2013 | 09:07 AM
Thanks for the help guys! one more question.. How do I torque them if its a allen head bolt?
Old Feb 28, 2013 | 09:17 AM
With a hex driver socket
Google
Old Feb 28, 2013 | 10:06 AM
This is the important part, though... the "alan" part of the bolt only needs to be torqued to 3Nm. You torque it, it centers on the frame. Then you hold it in place and tighten the castle nut on the outside to 49Nm. This keeps the spacing even. DON'T tighten the alan bolt to 49Nm, it's a spacer and will just spread out your frame.
After the spacer is torqued to 3Nm and then the lock nut is torqued to 49Nm, then you can install your extended hanger bolt to 39Nm. It's trickier than just torquing it, hence my ******* first response.
Ideally, you have a special tool to hold the alan bolt while you tighten the castle nut. I just put a mark on it an eyed it to make sure it didn't move (backing it out slightly as it turned with the castle nut).
Worst case scenario, just don't overtighten the alan bolt as it will twist your frame, and install the extended hanger bolt to 39Nm and use plenty of blue loc-tite on the castle nut.
jscobey
Sep 30, 2014 10:51 AM
Old Yeller
Jun 1, 2010 08:44 AM
ebbhead
Apr 10, 2010 01:50 PM
REDVTR1000
May 14, 2008 06:17 PM
mamisano
Sep 4, 2004 04:48 PM
