dropped my bike
so i dropped my bike, i was going down my steep driveway and hit my rear brakes and it locked up. I managed to completly stop the bike before it fell over, minor damage the right front factory turn signal took 95% of the damage which is good because I have a few spares. however now it wont start :mad: cranks over but no start. any ideas
thanks |
Check to see if you bumped the kill switch to off.
Kickstand switch, clutch switch, kill switch.
Check the easy stuff first. |
also when i got the bike pushed back into the garage i noticed no oil was in the sight glass window even after sitting for 20 min or so
tilt the bike vertical to check oil.
yea i did have it standing vertical while i looked
What was the level before it fell over?
Originally Posted by BlackHawkCBR
(Post 312944)
in the middle between the top line and bottom line
HAve you cracked a cover and is there a puddle somewhere
Or if it tipped arse over tit then is there any oil in the airbox |
no the bike was stopped at it was actually a real slow gentle fall onto the right side no crackes that i saw, no oil drips or puddles
See what it's like tomorrow cos it don't just disappear
i know i doesnt make any damn sense to me, i has to be somewhere
My bike eats oil like a mother****** I am short a few quarts every month.
Originally Posted by geekonamotorcycle
(Post 312964)
Originally Posted by wsharpman
(Post 312968)
sounds like time for a rebuild. Mine at 27k still uses none.
Under "normal" riding conditions mine still doesn't burn any oil.... ;) |
did ya flood the carbs? :)
I did the same thing on my VF1000F, and after I drained the bowls of all the excess fuel, she started right up. |
yea all i needed was to sit for the day is was at work, i got home and she fired right up. just needed the time. were all good
