coolant leak??
pulled in today after riding jacked it up on my stands. later when my rents got home I was showing my dad the new stands and we noticed a puddle of blue fluid on the ground... coolant leak maybe? I was thinking of tearing her down tonight to disable the pair system anyways as well as cleaning the carbs. what should I look for exactly? remove the side plastics to check out the radiators?? :?:
Originally Posted by EngineNoO9";p="
(Post 13603)
pulled in today after riding jacked it up on my stands. later when my rents got home I was showing my dad the new stands and we noticed a puddle of blue fluid on the ground... coolant leak maybe? I was thinking of tearing her down tonight to disable the pair system anyways as well as cleaning the carbs. what should I look for exactly? remove the side plastics to check out the radiators?? ?
I'm replaceing the waterpump seals as I type. In fact done,, Just need to add some coolant and oil in the morning |
Re: coolant leak??
can you post a pic of exactly what you're referring to?
Re: coolant leak??
It's number 2 in this fiche:
http://www.ronayers.com/fiche/200_03...0&parent=13160 Factory manual calls for a special tool to remove it and a hydraulic press to install it! :( Me? I used a small socket extension to knock it out and a deep well socket and hammer to install. Have about 3k miles on the new seal and impeller. The impeller looked different from the one I removed from my 98. I assume it was the original. You never hear of new owners asking about coolant drips. |
Originally Posted by superbling";p="
(Post 13624)
http://www.ronayers.com/fiche/200_03...p;parent=13160 Factory manual calls for a special tool to remove it and a hydraulic press to install it! :( Me? I used a small socket extension to knock it out and a deep well socket and hammer to install. Have about 3k miles on the new seal and impeller. The impeller looked different from the one I removed from my 98. I assume it was the original. You never hear of new owners asking about coolant drips. I build tools... so it was not a big deal to make something that worked for seal install. Pilot shaft was a bolt, center piece was a small blank I cut to fit the seal diameter. And the part that presses the seal in was a old socket of the correct diameter. I save and or buy old used sockets for tool making....lol Never the less.. I thought he was asking about the weep hole. It is located in the right hand cover, mid way between the outer edge and the inside edge that meets the case half. On line with the center of the water pump. I do not have a pic,, but will take one and post if needed. Look at your right hand cover. put your finger in the center of the water pump. Trace a point forward till it goes around the cover,, towards the center of the motor. Your finger will go right across the weep hole. It is there simply to allow coolant to leak past the seal and escape the case,,,and not be forced into the motor, and oil supply. |
Originally Posted by bronco78";p="
(Post 13625)
Blue? You sure it isn't laundry detergent?
Originally Posted by jschmidt";p="
(Post 13650)
