chain and sprocket conversions....
i know this has been beaten to death, but what are anybodys thoughts on conversions and any recommendations? i currently run a did 530 chain, stock 43 tooth rear and 15 tooth front,(best mod for the money, thanx guys!) all input is welcome!
I bought the 520 chain and sprocket deal on Ebay with the 15-43 combo. I've been real happy with it for the track, for street I bought a 41 tooth rear because I'm always looking for one more gear on the street with the 43. So far the chain has held up real well and no noticable wear to the sprockets.
Re: chain and sprocket conversions....
520 with 15/43 and I love it no problems with 2,000 miles on the chain so far cost $220 bucks
Do you guys know what your top speed is? We've got some spectacular roads here and I regularly top out at 250km/h (by the speedo) and can't keep up to some of my buds. Irregardless, I'd be happy if I could hit 230 after the converson but no less.
Originally Posted by NOrrTH";p="
(Post 14724)
That's dayum fast :D About what was your RPM at 155MPH (250KmH) ? Was it redlined? Best I've done around here was about 130MPH indicated (1.61 x 130 = 209.3KmH) |
what brand and what else does the 520 conversion kit fit....i am having a little trouble finding one for a Shawk....does anybody know if the chain and sprockets from a f4i are the same I.E. number of links and what not?
I used Vortex sprockets,1down front 2 up rear w/520 DID chain,it rocks for me! I,ve put about 8000 mi. not wearing as well as stock but who cares.
Originally Posted by call me phil";p="
(Post 14739)
A shop in Austin, TX sells a 520 setup for $139.99 on ebay That's where I got mine. You need a chain tool to install (if you don't already have one) RK chain, vortex steel front 15, & vortex aluminum 43 rear |
I got mine there as well. The f4i is different but it looks like the 919 is the same as long as the chain is the same length, best thing to do is cross referance the numbers. Here's a link to the place on ebay.
http://cgi.ebay.com/ebaymotors/HONDA...QQcmdZViewItem |
Thanks superhawk22 !
I was at work & couldn;t link to the ebay auction (ebay is blocked at work) If you get one you won't believe how much lighter the chain and sprockets are! I should have weighted them but didn't :( It must shave a several of pounds off the weight of the bike....well, at least a pound or two! |
(Post 14739)
Have not gotten mine yet,, should be here today.. so this is less recommendation, and more just info as to another supplier. |
I don't know of any VTR high mileage commuter types running a 520 setup so the answer may be a long time coming but I wonder what kind of life span these have compared to a 530?
Of course any properly maintained chain run under an even partial throttle will last longer than one with spotty upkeep subjected to full throttle runs through the gears. So unless it's the same rider doing the "tests" who doesn't change his riding routine, we will never really know. I guess in a way I just answered my question. |
Well then I'm lazy with mat. and do full throtle through the gears at the track so if it's going to wear fast I can tell you. Oh and lots of chain stretching wheelies too!! :lol:
Originally Posted by CNI Dawg";p="
(Post 14731)
Lets see.... 250 KmH x 0.6214 = 155.35 MPH
That's dayum fast :D About what was your RPM at 155MPH (250KmH) ? Was it redlined? Best I've done around here was about 130MPH indicated (1.61 x 130 = 209.3KmH) So no one knows what their top end is after this conversion? |
Did you guys recalibrate your speedometers? If so, what 'box' are you using. I've got several sprocket sizes laying around but have been hesitant to switch because I want my speedo to be correct. Any suggestions?
Jamie Daugherty http://members.iquest.net/~daugherj |
Originally Posted by JamieDaugherty";p="
(Post 14808)
Jamie Daugherty http://members.iquest.net/~daugherj Stock Sprocket sizes are 16 th front 41 th rear with a final drive ratio of 2.56. The 15 tooth front 43 tooth rear kit has a final drive ratio of 2.87 |
North, I could try to find out for ya but my speedo is way off so it wouldn't matter what I told you. I have 15-43 and mine is off more than stock.
So, I guess my original question still stands: does anyone use a speedometer recalibrator? I know that the stock speedos are off, I'd really like it to be correct. Any suggestions on what works best from persoal experience? Thanks!
The guy at Speedohealer said Honda's stock speedo error was about 5%
I used the calculator to figure in the change to 15/43 and came up with 15.6% correction with a fairly new tire. This seems to be pretty accurate just based on how fast it says I'm running compared to other traffic. Hmmmmm.......maybe I can find one of those remote radar display units they leave on some Dallas streets to deter speeders ! Anyway....Check out the Speedohealer calculator here: http://speedohealer.com/eng/adjust.htm BTW the speedohealer is a simple plug & play type installation....no wires to splice just plugs into the factory wiring harness. I had 1st tried an 8% stock correction baseline but it was way off (17.6% total correction with 15/43 gears) Need to borrow a GPS & test it to be most accurate. |
A lot of us are using bike computers, very accurate.
Sigma 1200 avalible at REI @ around $20. Some other good functions as well like 2 trips, av speed, and max speed recorded. Lower gearing makes your stock speedo read even higher than it was with stock gearing. ~Jeffers |
Is 15/43 too much do you think? Going into my 3rd year on the VTR now, I was thinking of just dropping the front down 1. Will this not be noticeable?
Originally Posted by caffeineracer";p="
(Post 14834)
Sigma 1200 avalible at REI @ around $20. Some other good functions as well like 2 trips, av speed, and max speed recorded. ~Jeffers http://www.gearandtraining.com/index...D&ProdID=21814 $20 here.... |
Sigma BC1200 $14.95 @ Bike Nashbar
http://www.nashbar.com/profile.cfm?c...eid=&pagename= |
Originally Posted by pickle.of.doom";p="
(Post 15664)
Here is a gearing calculator that will tell you how fast you should be going in any gear. Type in the proper valeus and you will have the info. At least you can see how far off you speedo is.
http://www.jahlmandesign.com/gear_calc_mph.htm All the gear ratios are in the owners manual. |
The best I have done is 157.06 GPS verified. That was hitting the rev-limiter.
Originally Posted by cbenson666";p="
(Post 16540)
Is that with a 15/43 ? |
that was with a 16/43
installed on mine: sunstar front sprocket, vortex rear, and an RK 530 chain... down 1, up 7... i dont care too much about top end, obvisouly... but damn... 3 gear, front end still wants to come up
UP 7:shock: what does your bike do like 80 miles an hour? :lol: that must be scary in 1st gear.
| All times are GMT -7. The time now is 01:54 AM. |
