carb cleaning
Hi guys it been a while since I been here. Short intro I got the hawk to turn over
And run on starter fluid but she won't stay on. There is fuel in the bowls. I decided to Dip the carbs and my question is. Is the any other plastic or rubber besides the Floats, diaphrams, and stuff on the outside ofthe carbs. I don't wanna ruin good pieces. What else am I missing? |
Dump the fuel in the tank and lines. Down load the service manual if you do not already have one and follow to disassemble your carbs.
https://www.superhawkforum.com/forum...ad.php?t=11365 |
I will check when I get out of work. It won't dl to my phone. I got it on pc tho.
A little more about the bike. Earlier it ran crappy for about 10 seconds. Both headers are hot and when I loosen the screw under the float there is fuel. The rich screw thing underneath both carbs were turned out 4. Idk if its got a Kit I will check also. All I can think of is very dirty carbs. This bike has an engine swap (bad ccts first engine), replaced rr and to top it off I broke the only key in the tank lock trying to get all the old gas out. Since then I Dismantled the fuel cover and ignition, put fresh gas and seafoam. I already cleaned the Carbs once but I didn't dip them. Now that's what I'm gonna do. |
Assuming it actually is gummed up carbs, I'd try this first. Get some Yamaha Carb Cleaner part # ACC-CARBC-LE-NR. Costs about 10 bucks a quart.
Drain the float bowls and close their valves. Pull both fuel lines off the tank and pour carb cleaner down each one until you know the bowls are full. Leave it in for a few hours and rock the bike good a few times each hour. Worked good for me with a bike which had been sitting for years. Pulled the carbs a few weeks later to change jets and the insides looked brand new. |
+1 I used the yamaha stuff too on a few old bikes that had been sitting for years. So easy I wish I had known about it sooner.
I was using vavlolene(sp) carb cleaner. And there was a black gunk in both carbs after I was done trying to start it.
I did blow into the fuel line and gas only came out one nozzle ? Both carbs. But Was hard to force the air in. |
If the carbs are off the bike, an old trick is to disassemble the carbs and put the jets in the float bowl. Add Yamaha carb cleaner. Then put a torch with a low flame under the bowl and bring to a boil. Let cool the do it again with fresh cleaner. Boil until clean. Takes about 10 minutes total.
Originally Posted by motojoe
(Post 199672)
Side note there was a thread awhile back where the guy stuck his carbs in the dishwasher but I couldn't find it. Ill write back with what ever results. |
(Post 199672)
Hmmmmm.... and if you were to substitute 151 rum? Had not heard that the Yammaha carb cleaner was so good, but for what it is worth everyone on the yamaha jet boat and waverunner forum swears by Seafoam. I've never soaked my carbs in the stuff (others have) but I use it as fuel additive on my boat and skis. |
ok i got it all back together, she still wont start, turns over strong but nothing after that, reassembled the pair stuff because the vacuem(sp) caps were cracking, now the plugs are good, idk if theres spark but she ran for about 30secs previously on alota started fluid, could i have clogged strainers in the carb even though i dipped them??? im missing something
also i dont smell gas in the exhaust, the plugs werent soaking wet but they were moist?? should i give the enrichener screws another turn out??? right now they are 2 turns out ill check in tomarrow im tired and going to bed, LMK if yall have any ideas :violin: |
Originally Posted by bigjay77
(Post 199954)
The only thing I soak are the jets, in the Yamaha cleaner. Been doin it since 1987 when another mechanic showed me that trick. Line techs work on commission. It was quick and easy and the bike ran that same hour. I have never soaked bike carbs like you would a carb for a car.
Ok I'm about to show my ignorance.
When I cleaned the brass tubes they didn't have a hole straight thru , all the side Holes were cleaned tho. Another thing of the 4 brass pieces the one seperate and Angled didn't have any holes. I think its the one that the diaphram needle goes into. Did I just not clean them well enough? The only hoses that aren't connect are the air cut off valves and they are plugged. Fuel is pouring out both sides of the petcock so I know its not clogged. |
Progress. She turns over now a few times. I stuck guitar wire thru most of the holes.
I'm gonna chem-dip the carbs over night. There was exhaust smoke coming out so I'm close. I also went 2.5 turns out on enrichener. I'd would be nice to ride her this track season. Sorry I sound so squidy its just my first carb cleaning. |
I got pretty lucky. my girl has been sitting almost a year. the gas smelled "meh" so I dumped 2 gallons of fresh on top of it. she was pissed off as hell, ran on one cylinder for about 10 sec, but finally coaxed her back to life. sounded pretty good for being dirty as hell.
now she's off to get some "work" done to the top end while i decide what to do about carbs. :bananadance: |
Step by step:
1) Go to Yamaha Dealer and get some Yamaha Carb Cleaner. 2) Disconnect fuel line to carb. 3) Drain fuel from float bowls - Retighten screws. 4) Fill fuel line and carbs with Yamaha Carb Cleaner. 5) Let it sit for a few hours. 6) Drain float bowls. 7) Reconnect fuel line and turn on bike. Allow to run for a few minutes. --------- OR --------------------- If you already have the carbs off the bike and the jets and float bowl off the carbs, do the following: 1) Put all the jets in one float bowl. 2) Put the float bowl in a bench vice -do not clamp down on it hard. 3) Fill the float bowl with Yamaha Carb Cleaner about half way up. 4) Fire up propane torch and heat up the float bowl until it boils. 5) Allow it to cool. 6) Sit back and ask yourself why you never did this before- cause it's so damn easy! 7) Reinstall jets, carb and fire up the bike. |
| All times are GMT -7. The time now is 11:32 PM. |
