Originally Posted by Malice
(Post 210742)
I would almost guarantee the frame is not heat treated due to the cast pieces that are part of it. Unless in 1997 Honda decided to start using a vacuum casting process, which I seriously doubt, they would not be able to heat treat the finished frame.
I figured out that for production purposes it may be cheaper to build a heavier frame not heat treated. The more I look at it the more I see benefits to reinforce some parts of the frame, that swing arm really looks like it could use some stiffness. For those who did, how is the ride now ?? |
Originally Posted by steve.g
(Post 209849)
Got my swingarm done. Found a nice carbon fiber chainguard for a 900rr that fits. Still not sure what the final finish will be, maybe silver powdercoat, but whatever I choose, won't do it till next winter....:D
Looks very nice. Makes me want to brace mine as well. |
am I wrong in my admittedly superficial understanding of these things? but I thought to properly weld to reenforce a frame required the frame to be placed into a jig to ensure no shifting during the heating of welding, or you could lose as much as you gain in other areas? Am I just stuck in the steel frame era?
Originally Posted by cliby
(Post 210782)
thats why i braced mine with the engine still firmly mounted. |
You could just tack weld it and let it cool, then weld in small passes, letting the heat spread in the piece or letting it completely cool between passes, it should stay straight.
So we are talking about sideways movement, up/down or both ?? |
Originally Posted by gboezio
(Post 210795)
(Post 210795)
(Post 210772)
So cast alloys are not heat treatable
________ Yamaha Yx600 Radian History |
