Accelerate in first without wheelying?
For the life of me I can't go fast in first gear or my front wheel will come up. Doesn't matter what I do.
Any RPM below 8 grand and my front wheel comes up. I even tried practically sitting on top of the gas tank. Still almost flipped. I've tried gradually rolling it on, but I can't twist the throttle past 75% without it wheelying. Any suggestions? Could it be suspension? Or is it just not possible to go fast in first? I usually just skip it and go into second. |
Check the gearing... If it's the stock 16/41, it's possible with a little finesse, but takes practice... If it's not stock, it's just about impossible...
(Post 355082)
I just changed to a 16/43 setup and I have no problems keeping the wheel down...
Originally Posted by Tebs
(Post 355086)
Infact, getting my bike to full throttle in second or third without standing it up, takes a bit of finesse... While I'm running stock gearing, there is nothing stock about my engine... I'm actually contemplating going to longer than stock gearing... |
(Post 355086)
As for the issue of stock gearing and keeping it down, it is very possible unless you are pinning it between 2500 to 5k, in which case its most likely going to come up, BUT thats the fun of the hawk right? :cool: |
Originally Posted by sailorjerry
(Post 355098)
i can tell you that if you can hit anything past 40 to 50% throttle in frist and keep the front wheel on the ground then there is something wrong with your bike, i too just changed to 16/43 and i pull the wheel out of every first gear corner.
That's why I went to 15/42 gearing. First gear is to get off of stop. Shorter gearing lets you use 2nd off slow corners. The transmission shifts better and you get the bike stood up as you are rolling into the fat part of the torque band, so it's easier to ride hard.
(Post 355098)
Originally Posted by Chrisguilday
(Post 355079)
Any RPM below 8 grand and my front wheel comes up. I even tried practically sitting on top of the gas tank. Still almost flipped. I've tried gradually rolling it on, but I can't twist the throttle past 75% without it wheelying. Any suggestions? Could it be suspension? Or is it just not possible to go fast in first? I usually just skip it and go into second. The bike has a certain torque at the rear wheel when the front wheel will come up. It doesnt matter what your gearing is, the minimum time accelerating from 0 to 40mph (or whatever) without wheelieing is still going to be the same... Or are you purely wanting to be able to thrash first gear without wheelieing, and dont care about your speed of acceleration? If that is the case, go get a 17T front sprocket and a 38T rear or whatever. |
Originally Posted by Codeblue
(Post 355124)
Shimming the rear had a noticeable side effect of making the front end harder to pick up for me.
Pull the front plug wire..... ;)
lol!
Originally Posted by 8541Hawk
(Post 355134)
That would make it a VTR500f right? :rotf::rotf::rotf::wheelie: I say dont worry so much about fixing it but learn how to control and enjoy it. Like i said earlier thats one of the many things makes me love the hawk over I4's. |
(Post 355079)
Yah, ya can. Just consider the cops are watching and a wheelie can be a 'go to jail, wreckless driving offence'. I been stopped twice in the last few months. First time I was mistaken for a runner. When I took my helmet off and with his hand on his gun officer said "well, you ain't the one". Then we both laughed and had a good talk. Second time I was at fault for expired tag (8 months expired). So, they're always watching and you will get caught. :cool: |
Put on a hundred pounds, mine only slightly comes up and is good fun. ;)
i cant give it more than 1/4 throttle in first without looking at the sky ,,, tis fun
I'm running stock gearing and I can't lift the front with just power alone in first. No way in second unless I bang the clutch. I assumed it was the elevation (4200 ft and above) that I ride at, but maybe my bike is down on power. It pulls very smooth with no flat spots (that I can feel). I am a squid so that could be a possible reason.
Originally Posted by xeris
(Post 355222)
Originally Posted by lloydievtr
(Post 355217)
What can account for such a huge disparity between machines that develop about 65lb ft of torque? Truly shocking! |
| All times are GMT -7. The time now is 01:31 AM. |
