Garmin Nuvi help needed (gpx files)
Old Jul 15, 2010 | 07:52 AM
Question Garmin Nuvi help needed (gpx files)
Do any of you use .gpx files w/ your Garmin? I'm having trouble loading shared files. Any help is greatly appreciated!
I've transfered them to the unit in the gpx folder and on the memory card. When I find them in the My Data folder and select them, my unit reboots itself.
I have a Nuvi 855.
TIA
Old Jul 17, 2010 | 06:00 AM
Hawknut's Avatar
Hawknut
I don't know if you can find what you need here.This guy really has alot of info on the Garmin Gps. http://home.comcast.net/~ghayman3/ga...m#pageinfotext
Old Jul 17, 2010 | 08:04 AM
mattmcgyver's Avatar
mattmcgyver is on a distinguished road
Have you tried a firmware update? Usually if I find a new data set does something like what you just had happen it's because I'm running a new data set on an old software... go to garmin.com and plug in your device with a usb cable and run the update...(free)
Also, make sure that the card you're using is compatible I'm not sure about the 855, but I had a problem using a 8g on a 260 but the same data on a 2g was fine... go figure.
Old Jul 18, 2010 | 01:38 AM
Firmware is up to date. I have no memory card issues. It has mp3 capability and I have a bunch of music on there that I listen to with no problem.
I have looked around that website before on someone else's recommendation. Maybe I'll browse around some more to see what I can find.
I appreciate your trying to help.
skokievtr
Oct 15, 2010 07:45 PM
dealrocker
Feb 28, 2010 08:55 AM
Crawdaddy
Mar 17, 2009 03:39 PM
2wheelust
Mar 7, 2009 08:04 AM
superbling
May 23, 2008 01:11 AM
