SuperHawk Forum
-   Everything Else (https://www.superhawkforum.com/forums/everything-else-31/)
-   -   Blown engine in your future? (https://www.superhawkforum.com/forums/everything-else-31/blown-engine-your-future-35152/)
mikstr Oct 9, 2018 06:12 PM
E15: a sure path to problems...
https://www.msn.com/en-ca/money/tops...id=mailsignout
captainchaos Oct 9, 2018 09:29 PM
But the EPA says it's "safe to use in VIRTUALLY all vehicles 2001 and newer," whatever the hell that means...
In all seriousness as of now it seems we still get a choice at the pump. Hopefully there doesn't come a time when we're forced to use it. I already pay another dollar a gallon for REC90 in my Superhawk because I don't ride it nearly as often as I drive my car and because f$&k the EPA...
mikstr Oct 10, 2018 04:32 PM
Anyone with a bike, snowmobile, small engine, boat,... in the US ought to be worried...
No talk of this nonsense in Canada yet, hope it stays that way...
JamieDaugherty Oct 12, 2018 05:55 AM
We've had between E10-E15 in all gasoline, even premium, here in the States for years. I wouldn't be too worried.....
If you still are, you can find the nearest non-ethanol gas station here https://www.pure-gas.org/
E.Marquez Oct 12, 2018 05:59 AM
Yes And I have been racking up the labor hours in the last 10 years fixing the issues it causes.
"Blow up" a motor? Well no... Damage fuel system, cause tuning issues, decrease power YES
captainchaos Oct 12, 2018 06:12 AM
Really? I was under the impression (and it states so on the pump for whatever that's worth) that it's "up to 10%." And I was of the understanding that there's a pretty good difference between E10 and E15.
captainchaos Oct 12, 2018 06:20 AM
Don't forget damaged valves and valve seats and destroyed catalytic converters. Studies have already shown it.
mikstr Oct 12, 2018 05:11 PM
Can't speak for the US, but here in Canada, much of our gas is/contains "up to 10% ethanol". The marine engine association and snowmobile manufacturers association (and other "small engine" manufacturers) have carried out extensive testing on E15 in recent years and the verdict is clear and unequivocal: it kills engines (the additional leaning caused by the ethanol is enough to push things over the edge). Virtually all small engines are approved for up to E10, you're on your own with E15.
Just another totally asinine move by people who should know better.
I have not heard of any move to do the same here in Canada and it hope it stays that way...
Wolverine Oct 12, 2018 09:12 PM
Well the alternative is to hurry up and run out of gas an switch everything to electric...
Maybe we can stop all the useless racing around in circles wasting it? :lol:
DoctorCat Oct 18, 2018 01:38 PM
we have ethanol in US gas because our farm subsidies and economics are completely out of control and so the government agreed to buy surplus corn from farmers, and didn't know what to do with it. As a result there is a huge industry of how to put corn into everything that we own. It's in our sugar, and now it's in our gas tanks. I wouldn't call it a "renewable" fuel because it costs a significant amount MORE petrol to grow it than the energy you get out of it by putting it in your tank. It's a waste, and it's pretty crap for your fuel system.
kenmoore Nov 1, 2018 03:12 AM
In Oz we have E10 as well as 91, 95 , and 98 with no ethanol at the bowsers.
I live in a district that has a huge ethanol plant and it stinks . The smell is obnoxious and I sold up and moved further away .
I run the Storm on 95 and use a valve saver lubricant every fill.
When E10 first came on the market a lot of people complained about it however , I do use E10 in cars !
I consider us to be lucky here .
mikstr Nov 3, 2018 08:05 AM
After reading a thread on the Bobistheoilguy forum and doing some additional research on the matter, I stated adding a small amount of two-stroke oil at every fill-up. In addition to helping with top-end wear (upper cylinder and valvetrain), it also helps with ring sealing, giving a small boost in power. The detergents are also said to keep everything clean.
captainchaos Nov 3, 2018 10:39 AM
Wow that's very interesting. Is this the same thread you were referring to or is there a different one?
https://www.bobistheoilguy.com/forum...Number=1107478
mikstr Nov 3, 2018 11:12 AM
One of them. One chap noted that they saw a 2 hp increase (on dyno) on a 450 MX.
Here is one of the threads that got the ball rolling: Been testing Oil
Can't be against free horsepower, smoother running and better wear protection, can you?
kenmoore Nov 3, 2018 01:18 PM
The valve saver lubricant every fill has become and OCD with me .
I feel guilty if I don't do it, one thing that it seems to do is lessen valve adjustments. I check the valves as part of my maintenance routine and have only used two shims in 60,000 Klms.
Happy with that !
mikstr Nov 3, 2018 03:19 PM
Happy with that !
which brand valve saver are you using? Flashtune?
kenmoore Nov 4, 2018 01:48 AM
The one I use is Flash tune I think . Heven't paid that much attention , as long as it says valve saver or lead replacement that's what I use.
Like I said, every fill !
mikstr Nov 4, 2018 06:33 AM
cheers
Butts Nov 8, 2018 10:51 PM
Ken, interesting. I'll look at starting to use it at every fill. Flashlube I think it is.
How much do you put in by the way? I have a 98, so small tank.
I fill with 95, any difference using 98 or 91 by the way?
Wolverine Nov 9, 2018 06:26 AM
Manual states 86 octane and up. I've used 87 since day one, never any detonation and it's never run "better" on the expensive stuff.
mikstr Nov 10, 2018 11:02 AM
well, I took the plunge and ordered some valve saver fluid. Having spent significant money on this last rebuild (which will be its last) and with the engine (indeed the entire bike) running incredibly well, I want to do everything I can to make it last, which includes keeping the valvetrain fresh and tight.
