SuperHawk Forum
-   Ebay (https://www.superhawkforum.com/forums/ebay-44/)
-   -   Penske Shock (https://www.superhawkforum.com/forums/ebay-44/penske-shock-14943/)
Blue Ridge Boy May 27, 2008 07:58 PM
Penske Shock
http://cgi.ebay.com/ebaymotors/ws/eB...m=190225485571
......Yeah......I'm bidding. :cool:
joshuatest May 27, 2008 08:06 PM
Ummm... yea.. I want it...
Blue Ridge Boy May 27, 2008 08:09 PM
go away joshua...you already have your turbo. :p
joshuatest May 27, 2008 08:25 PM
Thats why I need a new Shock... That turbo of mine is kicking the stock shock's ass....
sassage May 27, 2008 10:01 PM
dude, shut up...I'm already in the bidding process
nothing can be a secret around this place :rolleyes:
KindredGhost May 27, 2008 10:30 PM
I just bid 1 MILLION dollars. It's MINE!!!
KG
(JK btw... yeah, i want it...)
taskmasta May 27, 2008 10:36 PM
sorry if i outbid you.
sassage May 27, 2008 10:39 PM
are you really sorry? ;)
taskmasta May 27, 2008 11:00 PM
no not really...but there is still alot of time left. lol
sassage May 27, 2008 11:12 PM
there we go...a little honesty :)
in the interest of being a good sport: I asked the seller a few questions and he said 15,000 miles & set up for 190 lb rider
trinc Jun 5, 2008 08:57 AM
damn... $440.00 for a shock with 15k on it ( needing a rebuild ).
amazing.
tim
sassage Jun 5, 2008 09:11 AM
amazing.
tim
no doubt...I dropped out fairly early in the bidding. did somebody here get it?
superbling Jun 5, 2008 09:20 AM
Yeah, a forum member got it. It's ironic that riders balk at paying for suspension (I was one) but happily fork over big bucks for hollow steel tubes with some fiberglass stuff in the end.
My wilbers shock calls for a rebuild between 20-30K miles at $90-125 service charge.
sassage Jun 5, 2008 09:28 AM
I'll spring for some better suspension (too big a guy to stick with stock) when the money's right. just looking for lower miles if i'm gonna buy used. picky, picky i know
haven't heard much about wilbers, good stuff?
FL02SupaHawk996 Jun 5, 2008 09:37 AM
amazing.
tim
The cost of rebuilding that shock is astronomical! $2.90 for a spring and $0.75 for o-rings...stock shocks are a lot cheaper...just stand up over the bumps:eek:
http://www.resuspension.com/8100-p-1-c-79.html
and just forget about the added:bling:
lowell Jun 5, 2008 09:45 AM
Fully adjustability Penske is worth the bling.
I am just saving for a new one.
It seems every bike I have owned I upgrade the forks and rear shock to make it "right".
THen I upgrade the brakes.
I never seem to upgrade the motor.
FL02SupaHawk996 Jun 5, 2008 09:51 AM
I agree that the SH motor is fine stock cuz it's got lots of torque, but it would be nice to stuff an RC51 motor in there;)
Hawkrider Jun 6, 2008 03:02 PM
Yeah, the oil alone is about 4 times that!
FL02SupaHawk996 Jun 6, 2008 07:39 PM
Dangit! Now you have to buy new oil too to rebuild that sucker:(
Guess you'd be better of running a 2x4 back there;)
RC
filter69 Jun 6, 2008 10:54 PM
Well lets see new penske shock is 751.00 ge got used for 440 which is a differance of ....311 Dinars let find out how many rebuilds that is ....
Oil 16.32
Orings and misc 8.99
do it your self labor .Priceless
Shaft Wiper 8.00 (yea i know other shaftwipers too)
metering rod 7.00
and new pistons 1.50
for a total of ...Drum roll plz...35.81 total rebuilds 8 almost 9. im sold
Penske 2-Way Shock
$835.00 $751.50
http://www.le-suspension.com/catalog...ixel_trans.gifhttp://www.le-suspension.com/catalog...penske2way.jpg
Click to enlarge Leveraging the 8300 adjustment, the Penske 2-Way series is engineered for motorcycle road racing applications. The Penske 2-Way features 25 click adjustable rebound damping, 40 click compression damping and remote reservoir. This model has low speed compression adjustment only.
FL02SupaHawk996 Jun 7, 2008 03:42 AM
Oil 16.32
metering rod 7.00
Penske 2-Way Shock
$835.00 $751.50
Filter, that red spring looks sweet! Nice rebuild pricing too:)
Hawkrider Jun 7, 2008 03:46 PM
Filter, do you work at a shop that does suspension? How are you recharging the nitrogen?
E.Marquez Jun 7, 2008 04:53 PM
http://www.motionpro.com/motorcycle/...ge_and_filler/
filter69 Jun 7, 2008 08:18 PM
No I'm a HVAC tech nitrogen is an easy thing. I deal with high pressure
liquids and gases all the time. I have used my manifold guage set to recharge many reservoirs.
Hell for that matter you could prolly go to your local gas dealer and pick up a 40 cu. in nit tank and a regulator and be
filling in no time ...
E.Marquez Jun 8, 2008 03:10 PM
Regulator and tank are easy.. It's the set u0p to attach to and fill the shock.. Not as simple as a tire valve air chuck.
Being able to precharge the gauge, hose all the way to the needle valve is the key.. You get a perfect charge with zero pressure loss when you disconnect the set up.
FL02SupaHawk996 Jun 12, 2008 07:35 AM
Why not repressurize with air instead of nitrogen?
FTMS Jun 12, 2008 09:29 AM
Nitrogen is a lot more stable than air. It's pressure doesn't change do to temp.
FL02SupaHawk996 Jun 12, 2008 10:04 AM
Oh, that make sense, but does this? If you're not racing and just doing spirited commuting wouldn't you be okay with just air cuz it's 78% nitrogen?
found this surfing: Standard dry air is mainly composed of three gases: nitrogen (about 78%), oxygen (about 21%), and argon (about 1%). Together, these three gases make up 99.96% of dry air.
filter69 Jun 12, 2008 11:28 AM
Well nitrogen is DRY and normal air is not so you would have to deal with possible corrosion. Also the normal air may react with the oil turning it acid
or what have you to many variable's just use nitrogen and all will be well :)
FL02SupaHawk996 Jun 12, 2008 11:35 AM
All good points Filter, but since I can't fart nitrogen and I don't want to pony up for the tank and filling regulator I'll just have to let you know if I get make any acid or get corrosion problems in my remote reservoir at my next rebuild interval...:rolleyes:
Thanks bro!
RC
