Lots of parts
Hey guys I have a bunch of parts I'm going to be selling I laid my bike down last fall and the insurance company replaced everything even if it was just scratched soooo. The bike was laid down on the right side I will have a parts list later today but there were a few parts that were very expensive and are still useable was wonder how much they were worth the right side case cover only has a small scratch i mean i could be sanded and painted and nobody could tell and the gage cluster was alot of money as well it just has the right side screw flange broken off im sure somone could make somthing so it would work fine. I also have a few body parts that are in pretty good shape I have headlight assembly too. Like I said I will post the whole parts list later today I really have no clue how much any of it is worth so I will just take offers... Thanks Frank
You take $10 plus shipping for the headlight assembly?
Sent you a PM re. the Right Side Case Cover.
Did the insurance company replace the left upper fairing? (I know you laid down the right, but I knew a guy who did the same thing and the insurance company bought all new plastic up front including the left, so he had a spare left fairing...) If you have the left upper fairing I'd like to have dibs on it!
I could maybe use the left lower fairing... $$$?
Anyone know where I can get good pilot foot peg rubber inserts cheap?
Are you by chance getting the headers replaced?
The left side of the bike did not get damaged so they did not replace the left side fairing so I do not have an extra I do have a right side though that is scratched up pretty good. The headers did not get damaged so I don't have those either. Here is a list of parts that I can think of .. Head light assembly scratched not broken , plastic peice that goes around head light assembly, Right side plastic scatched up pretty good, right side case cover very small scratch is the only damage to it, stock windscreen with scratches and a crack if anyone has a need for that, some stock rear turn signals, rear plastic cowl only scratched on the right side a little does not look to bad really, front fender with some minor scratches going to try and buff them out in a day or two, Gauge cluster with 5k on it has a broken mounting tab I'm going to epoxy it back on and it should be as good as new, front brake lever just a scuff, perfect stock taillight, upper cowl stay just a little bent can be straightend out pretty easy I think, and im not sure what its called but the thing that the foot brake mounts on and the foot peg comes out of I have as well its slightly bent somone could prob use it though or try to straighten it out if I get some time I'm going to try to see what I can do with some of it... Anyways there might be more that I'm forgeting make me a few offers thanks guys...
the headlight assembly was 257.00 new it has to be worth more than 10.00 its only got a few scratches also if anyone wants or needs pics its not a problem......
Don't epoxy the gauge cluster tab, it should plastic welded...
Do you still have the tailsection ?
I'm looking for a damaged one to start with, so I have to admit I'm not looking to spend a whole lot of money. kai Ju |
I need the base for the right-hand-side mirror, the one with two bolts and a socket for the mirror arm. If you have it available, please email me at omarnazif at gmail dot com.
