HRC Ignition Box (CDI Unit)
Parting out a bike and have a a well running CDI Box. its in great shape. It will fit 98-00 modles and are very hard to find. (took us a while to find one any way) I'm asking $400.00 let me know if your interested...Thanks
What is the difference between this one and stock more advace ?
CDI
does it allow the use of street electronics? may take it!
HRC CDI
Hi Guys,
Well I'm the one who is actually sell the CDI unit. I had Gerry post it for me as I feel it's not real cool to join a site just to sell something but I guess I'll stick around for a while. :cool: Well that and the fact that I have limited internet at this time but Gerry appears to be busy right now, so here I am. Anyways to answer the questions so far. Yes it does advance the timing but unlike a static advancer it completly remaps the advance curve. It changes it enough that the fuel requirement with the unit is 91 oct. It also removes the side-stand switch (you can put the bike in gear with the stand down) and it also raises the rpm at which the rev limiter hit from 10.3k to 11k. Yes it will plug in and work fine with a totally stock bike. Everything will work fine (execpt the side-stand switch) and you will pick up a small gain in the upper rpm range. Where the unit works the best and where you will see the most gains is if you have installed the high comp. pistons and changed the cams. With this set up the CDI unit changes the advance curve to match the new power curve with the peak power comming at a higher RPM. Hope this helps and let me know if you have any other questions. Cheers, Mike |
It sounds really cool, and totally unneccesary. Someone please buy this before I am any more tempted.
I'd heard concerns before about raising the compression and advancing the ignition in that setting on the superhawk, using nonrace gas at least. Were you using this on a bike with HC pistons, stage 1 cams etc? Did you encounter any problems?
thanks |
Originally Posted by cliby
(Post 126872)
thanks |
Welcome Mike!!!
Sorry man i realy needed to email you back...thats all my bad...but at least your here now....I am glad to hear your going to stick around...there are some awsome people here too....kinda like sbr but all hawk owners....welcome man...
Originally Posted by Ogre8472
(Post 126936)
Originally Posted by Kendrick
(Post 126856)
Man I wish I was rich.
Well it's getting close to Ebay time.......
what makes it so this cdi only works on the 98-00 models?
Originally Posted by Zedicus
(Post 127455)
:bump:
Sold
Looks like this unit is sold..... thanks guys :thumbsup:
