FS VTR Carbon engine covers set
Old Sep 13, 2015 | 12:58 AM
jedrek750's Avatar
jedrek750 is on a distinguished road
Hand made Clutch & Gen covers set, 5 layers (3 carbon, 2 kevlar), glossy
Perfect fitting, easy mount.
93$ per set including shipping costs - worldwide shipping
Old Sep 23, 2015 | 05:47 PM
Got my covers today. Wow! awesome quality and super-quick shipping.
Two big thumbs up!!!!!!!
Old Sep 24, 2015 | 06:10 PM
bbancsov's Avatar
bbancsov is on a distinguished road
Would you sell the Gen cover separate from the clutch or package deal only?
Old Sep 25, 2015 | 02:51 AM
jedrek750's Avatar
Hello! Yes of course, but price will be little higher.
Gen cover - 33 £- including shipping
Clutch cover - 33 £ - including shipping
In this while engine covers out of stock ( all ordered), if You need more infos please send me a message.
Best regards jedrek750
Old Sep 30, 2015 | 10:32 AM
nekkid's Avatar
Hello Jedrek,
How do the covers attach to the engine and are they easily removed and reattached?
Old Sep 30, 2015 | 10:54 AM
jedrek750's Avatar
Originally Posted by nekkid
Hello Jedrek,
Hello! I use engine silicone gasket (easy mount and remove), some people use hard adhesive but easy remove is problematic...
Old Oct 6, 2015 | 05:46 AM
Jedrek,
Which image is correct, is the carbon exposed or the Kevlar? See my other reply to you regarding your frame covers related to the same questions I have regarding manufacturing and finish information that I have for the case covers.
Also, have you considered making a cover for the starter motor that would protect it from road debris AND cover the electrical cable connection?? Most people do not realize how much water creeps in past the little o-rings sandwiched in between the fiber insulating washers and metal case, which causes corrosion on the connection and inside the case. A very thin wrench is required to restrain the lock nut from rotating while removing the nut that retains the cable BTW! I recommend every one check, clean, dielectric grease and replace the o-ring ASAP.
Dziękuję
Old Oct 6, 2015 | 05:51 AM
FYI, if you use a silicone sealant / adhesive, us a neutral cure type as the acetic acid cure type (smells like vinegar) can damage the OEM urethane finish on the case covers.
Old Oct 6, 2015 | 06:55 AM
Jack Flash's Avatar
Well take off, eh.
Perhaps using the ThreeBond 1215 solventless silicone would be one of the good ones to use. I know it peels off nicely once finished with it.
Old Oct 6, 2015 | 07:11 AM
I do not recall how the 3bond 1215 smells but if it smells like vinegar I would NOT use it for this type of application.
Old Oct 19, 2015 | 10:51 AM
jedrek750's Avatar
Hi! skokievtr for sale was carbon set (upper image) , hybride covers picture it's my own bike.
Mount it on bike about two years ago (with engine silicone gasket), no problem with maintenance if you need check timing etc gen cover have holes, you can remove nuts and check everything.
Old Oct 28, 2015 | 10:11 AM
jedrek750's Avatar
SOLD!
Codeblue
Sep 1, 2013 07:45 AM
Crashrat
Jun 23, 2011 08:54 PM
Firestorm996
May 15, 2009 02:59 AM
epleeds
Jan 2, 2009 12:12 PM
epleeds
May 3, 2008 07:21 AM
