2Phaast |
11-16-2006 11:15 AM |
F/S 2000 Engine
Now that I finally finished the rebuild on my bike, I have my original 2000 engine leftover. It has approximately 18,000 miles, and was running strong with no leaks. Previously, it was dealer maintained. I partially disassembled it for valve/piston inspection, after a cam chain tensioner failed, with NO DAMAGE. The engine is completely original inside and out. There are no external components (cct's, carbs, airbox, spark plugs, starter, both side cases. Also no cooling, lubrication, vacuum, smog fittings). Engine sold AS IS with No WARRANTY. I will try to figure out how to post up some pics a bit later. If you have any questions, I will be happy to send photos. I figure $500.00 is fair, and shipping anywhere in US is $175.00 via UPS.
