Assorted parts
Assorted parts
2002 Honda VTR1000 Superhawk parts
2 stock seats. One is 95%, it has a small nick on the bottom edge of the cover (not visible when mounted), $50. The other one is about 85%, it has a nick on the front edge of the cover, a singed spot at the rear (almost not visible when mounted), and some drips on the cover on one side, $40
1st one: Sold
2nd one:
Clip-ons. The left one has some scuffs on the bar end. Come complete with bar ends and internal weights. $40
Stock fork springs. Pulled at around 20k miles. $10
Stock triple trees, forks, and brakes. Triples are straight, and have Allballs tapered steering head bearings installed. They also have .85kg/mm racetech springs installed. (with new races for the bike as well). Forks are bent. $50 (will hHave to unpack them for pictures) Triples, Bearings, and springs are Sold. Still have stock brake calipers and MC, w/ 954 lines
Stock front wheel with tire. Bridgstone 016, about 85% tread-life left. One lip of the rim is dinged, but it balances and holds air just fine (wheel was installed for over 10k miles as it currently is). $100
Left-side passenger footpeg bracket and footpeg $10
Sold
2 right-side mirrors. Minor scuffs on plastic, but glass in both is fine. $5 each
First Mirror Sold
2001 Suzuki TL1000S parts
Triple trees, forks, and brakes. Left fork bottom fender bracket is broken off, but functionally the forks appear fine. Bought in an attempt to fit them to my VTR, wouldn't fit the triples I had, so I ended up just using the wheel and clip-ons. They did come off what the previous owner described as a stunt-bike, so though they don't currently leak, I would plan to change the seals in the relatively near future. $150.
TL Parts all sold
2002 Suzuki GSXR-750 parts
Right fork leg. I think it's slightly bent, though it looks straight. Has stiction issues, even with rebound and compression damping set on full-soft. Upper should be good for parts. $25
Everything is listed for pickup. I've still got to get boxes for most of this stuff, so it will take a day or two to get quotes for shipping, but actual shipping costs (i.e. you pick UPS or USPS and I'll get the quotes) would apply.
1st one: Sold
2nd one:
Sold
First Mirror Sold
TL Parts all sold
niteridder64
Feb 20, 2013 10:18 AM
