Speedometer not working, then working again
Old 06-26-2009, 05:29 PM
superman_006's Avatar
superman_006 is on a distinguished road
Well just as it says, I took my 98 superhawk out today, I washed it and I didnt notice if it was working at first, then I was crusing and noticed it was sitting the peg (0) and the milage wasnt working. I stopped and ate somewhere and when I got on it again it was working fine?
I did the search thing and it sounds like the speed sensor is pretty reliable. Is there anywhere I should check for corrotion?
superman_006 is offline
Old 06-26-2009, 08:48 PM
2nd mouse gets the cheese
Little_Horse's Avatar
it may be your regulator rectifier, they do that when they start to go out, its no longer letting enough voltage get through to run the gauges and after you park it the r/r cools then works again for a little while
Little_Horse is offline
Old 06-26-2009, 09:09 PM
guru of things sparky
Circuit_Burner's Avatar
Yea if your battery or voltage levels do anything strange soon, you will know.
Circuit_Burner is offline
Old 06-27-2009, 02:26 AM
You just got too much water on the back of the gauges when you washed it.
Mine used to do the exact same thing, just be careful when you spray the water and even if it does happen again, it's no big deal as it will turn on again after it drys out and you cycle the ignition switch,
8541Hawk is offline
Old 06-27-2009, 07:04 AM
skoshere's Avatar
its the R/R. mine did the same thing as above, but went to a R1 unit and hasnt been a problem since
skoshere is offline
Old 06-27-2009, 07:29 AM
I did an r/r update about 2 months ago, the bike seems to be charging/starting better than ever.
Old 06-27-2009, 12:50 PM
Maybe water.
Im engineering a R/R and stator tester that I can maybe sell for at least 30 bucks.
Should be a nice piece of test equipment for serious bike owners.
Old 06-27-2009, 01:48 PM
Maybe water.
Well I've owned a SH for almost 12 yrs now and the speedo shutting off because it got wet is a common thing.
8541Hawk is offline
Old 06-29-2009, 08:27 PM
Ottawa, Ont.
Riff's Avatar
Riff is on a distinguished road
no, no, no... it's the speed sensor found just below the rear cylinder
Riff is offline
Old 06-30-2009, 05:46 AM
Ottawa, Ont.
Riff's Avatar
I should add that your symptoms are exactly what you will find when the speed sensor is on the way out, those bieng no reading on the speedo. and no progression on the odo.
The water theory is easy to eliminate, ride dry and if the problems persist...
Riff is offline
Skoal
05-17-2016 07:41 PM
Paradisd
04-24-2009 02:35 PM
EngineNoO9
10-10-2006 04:23 AM
EngineNoO9
04-10-2006 12:38 PM
reelectreagan
06-17-2005 07:31 AM
Quick Reply: Speedometer not working, then working again
