greetings from Sweden please, i need some help
hi to all. please first excuse my English, i speak it very well but write it worse :-)
Im building a Buggy using an Honda Varadero (carb version) that has had an Honda VTR (carb version) Engine transplant.
The bike was chrashed ang given to me for free. As i had the buggy chssies laying around.. i decided to make something out of it,
I have fitted the Engine. and wireharness - but wont get the Engine to fire at all.
the key part of ignitionlock was smhed. so cut it off. but tere are only Three wires in it.
also wonderiing if ll years of the Varadero / VTR had a tipsensor as stock ? nd if swhere would this be on the bike as i cannot seem to find it,
there are 2-3 places on the wireloom that might be for the tipsensor. etc etc
also. i have no instrumentcluster as it also was smashed totally so i donot know where to which each of the front located vireconnectors go to except the one for the ignitionkey
help meŽplease. IŽll gladly post Pictures for you.
/ Kristian / Sweden
/ Kristian / Sweden
vtr1000f%20wiring%20diagram.jpg?t=1492552716
I have attached a copy of the wiring diagram, and there is no tip-over sensor on the VTR.
Happy to help if I can.
Here is a dropbox link to the service manual for the VTR:
https://www.dropbox.com/s/wnh696qph5...1000F.pdf?dl=0
Looks like a fun project. Here are a couple more links that might help you out:
Tweety's Wild Thinking and say hi to Markus
also: vtr.nu - VTR-Klubben i Sverige ? Index
8541Hawk - thank you
Fastguy59 thanxs
Cadbury64 - here are two more oictures as i asked about. 1st on is located rear of the bike, about 45-50cm from the CDI /Picture without numbers on it
2nd is just ahead of the front coil wires
Fastguy59 thanxs
It's hard to tell from the photos but at a guess the rear one may be the brake light switch, and the other could be the fan motor connector.
It would be easier if you tell me how many pins in a connector, and the colour (main/stripe) of the wires.
Also please clarify, is the starter turning over but the engine is not sparking, or the starter is not working?
i just found out that the wireharnessess are not idetical on the Varadero / VTR - need to do som more checking / Pictures
as the Engines are the same i just thought the wires would be the same aswell.
Cadbury64: here are a few more questions :-)
I still need to locate on the harness which wireconnector is which . . .
1# Fan-motor wires
2# Fan-switch
3# Fuel level sender
4# Neutral switch / oil pressure switch (same connector ?)
5# Clutch switch
6# fuel cut-off relay
7# Fuelpump wires.. 2 or 3 wires ?
is the fuel cut-off relay necessary on a 4-wheel buggy ? does it act like an tip-sensor ?
:-) / Kristian
Headlight relayŽs.. 2 pcs. with each a 4-pin connector ? located just by the headlight bulb connectors ?
1# Fan-motor wires
2# Fan-switch
5# Clutch switch
:-) / Kristian
1# Fan-motor wires
2# Fan-switch: 1&2 are together, black 2P connector, black/blue and green wires. Black/blue is live to fan motor then to switch on radiator which completes ground circuit when hot.
3# Fuel level sender: low level sender is a 2p clear connector, brown/black and green/black wires.
5# Clutch switch: Black wires with right-angle boot/spade terminals on end, connect to both red and green connectors which also service the left switch pod (lights/horn/indicators)
6# fuel cut-off relay: Not on the VTR
7# Fuelpump wires.. 2 or 3 wires ? Not on the VTR; gravity feed only, no pump.
Bikes with fuel pumps use the relay to stop or start the pump. They also have a bank angle sensor to kill the engine in a fall.
:-) / Kristian
1# Fan-motor wires
:-) / Kristian
1# Fan-motor wires
2# Fan-switch
5# Clutch switch
:-) / Kristian
1# Fan-motor wires
2# Fan-switch
5# Clutch switch
:-) / Kristian
http://http://service.tanga-moteurs.ro/data/Honda_Xl1000V_Varadero_Service_Manual_En.pdf
many thanxs for the great reply.
yess. i do have the Varadero 1000 wireharness. which i noticed is similar but no more than that to the VTRŽs.
The Varadero has a fuelpump, fuelpump cut-off relay etc.. i just need to find the suitable wires yto make a new low preassure fuelpump. get giong as the Engine cranks.
So i have had the Engine running without the thermostat fitted to allow maximum waterflow to check for possible leaks . Im using an FZr1000 -89 radiator up front, which seems to work well. will fit an BMW kl1200 fan also, but will make the fan start with the fuelpump.
also done the entire exhaust-system & fitted exhaustwrap.
ItŽs LOUD :-)
ItŽs LOUD :-)
SpecŽs
1992 Swedishmade crosskart-chassie, brand new
Honda VTR V2 1000cc 130hp engine
520 o-ringchain
Honda Varadero wireharness
Yamaha FZR600 tfuelank
Aftermarket lowpressure fuelpump
Gocart-steeringwheel
Sparco raceseat
3" 4-point raceharness
Suzuki GSXR600 rear brakedisc
Twin ZX9-R 6-pots rear - one for handbrake, one for footbrake
Honda CBR1000 rear master cylnder for handbrake
Audi50/front brake discs, machined 20mm
Yamaha R1 -13 6-pots front
FZR1000 -89 radiator
Yamaha TZR125 expansiontank for rrdiator
tires front: 130/70-12 semi-offroad style
tires rer:ar20x10x8 or: 28x12x8
aftermarket rear brakelight LED
LED lightbar on rollcage
520 o-ringchain
Sparco raceseat
If you have no thermostat then the engine will be slower to come to operating temperature (about 80C), and may never get that warm if you are running steadily in cold air. On a buggy at low speed and in short bursts, that may not matter, but you would run the risk of moisture accumulating in the oil as it was not getting hot enough to evaporate.
