Which fork and tube mod? Mine take a beating.
Old 02-20-2017, 03:24 AM
RedStormJ's Avatar
I dont wheelie too often per se but the front end does come smashing down at 80 a lot. Basically the bike goes airborne every ride or two. Hence another reason why I am making it lighter.
Is there a big piston fork that isnt too heavy with some heavy duty seals I should use? Id go the same weight even a bit heavier as long as I can fit the setup on my bike. I know what fits and for now I am leaning towards a 1000rr front end but I know that will have the same issue or worse as the rr is lighter. Shes not leaking yet but I got a bulged dust cover so I am sure shes about to blow and wanted to order the front end soon.
also after getting the pipes. would I be able to make a lighter stronger milled titanium lower tripple clamp or should I stick with a factory unit. I can mill metal now but still no welder in sight...
RedStormJ is offline
twist
09-06-2012 05:15 PM
spitfirerecords21
05-16-2012 04:28 AM
theosagekid
01-22-2012 01:33 PM
rooster
03-16-2007 04:17 PM
superhawk22
12-30-2005 09:39 PM
Quick Reply: Which fork and tube mod? Mine take a beating.
