VTR TO VFR TANK Pro Modification !!
Old 03-24-2013, 08:23 AM
stesrg's Avatar
stesrg is on a distinguished road
Ok I have seen some great post on here to convert the vtr 1000 to a lager capacity gas tank so I Have done the mod myself with a beter view of a novice doing it with my guide .
1st of all the tanks
Then how they were bashed out very carefully using a rubber mallet
stesrg is offline
Old 03-24-2013, 08:31 AM
stesrg's Avatar
How the tank fitted to the frame
After several attempts looking at the origional tank to see were I had to bash it to get it to fit level on the frame , this was achived with me kneeling down with the tank on my legs and bashing it forcefully and trying not to achive creasing it .
This Is how I got it to fit on the frame after about 45 mins .
You can see the height difference it is a lot approximatly 70mm about 2 3/4" in your money I then fabricated an alloy bracket 1/4 thick slightly angled back around 20deg this was to line up with the holes on the tank.
stesrg is offline
Old 03-24-2013, 08:36 AM
stesrg's Avatar
The bracket
This is showing the alloy bracket how it sits on the frame .
once I got the tank right I offered a donor seat (vtr 1000 of fleabay) peeled back the covering and marked it like so
Once I roughly did it I used a frett saw and cut out the foam and plastic bottom
like so then I trimmed it to fit the countour of the tank
stesrg is offline
Old 03-24-2013, 08:43 AM
stesrg's Avatar
modification of the seat
Now as you can see in the photo I had to put a slight hump in the seat to cover the tank fixing bolts because the tank was 2,3/4" of an inch higher. Now then I made a template out of insulating foam stuck it on the seat with silicone and carefully shaped it out , this when finished went to the upolstery bloke and he put foam in its place and re covered the seat cost me 40 dollers or less
stesrg is offline
Old 03-24-2013, 08:50 AM
stesrg's Avatar
The Petcock
Ok as you know the VFR tank has an ingector pump in it this hole we had to blank off and use out original pet **** I got on from fleabay , I carefully made a template in cardboard and got this cut out using a plasma cutter and then drilled it , made a template of the contact surface of the petcock placed it on the stainless then drilled it out making sure the diameter of the main hole was the same as the plastic filter , this will then squezze it tight once the rubber O ring is fitted, the 2 fixing holes i decided to tig weld these to the inside of the plate to eliminate gas from leaking from them .
The original rubber gasket fitted but i had to trim off the spikes , I decided to buy a new one
stesrg is offline
Old 03-24-2013, 08:54 AM
stesrg's Avatar
I Have used the sender unit from the vfr and trying to get a guage to work from the cockpit of the bike as well as the orange low fuel indicator , however you can use the vtr 1000 sender and adjust this to how much gas you want left in the tank on reserve by bending the float wire up or down
I hope this has been of use to someone who is thinking of doing the conversion
Ste .
stesrg is offline
Old 03-24-2013, 10:49 AM
El Cheapo
cat0020's Avatar
Originally Posted by stesrg
Which tank is VTR and which tank is VFR?
cat0020 is offline
Old 03-24-2013, 11:19 AM
CrankenFine's Avatar
The one on the left is the VFR tank.
CrankenFine is offline
Old 03-24-2013, 11:22 AM
El Cheapo
cat0020's Avatar
VFR 750, 800 or else?
cat0020 is offline
stesrg's Avatar
Hi the VFR is the one on the left hence the big hole were the ingection pump went , the VTR is the smaller tank on the right with only the sender hole , and the pet **** is covered with the black rubber ( should have took this off realy ) It is off a VFR 800 as this one fits the frame of the VTR better and it holds 4 liters more !!
stesrg is offline
Old 03-24-2013, 02:32 PM
So did the sending unit/float fit right in the vfr tank, and do you have any pics of the full bike with the new tank?
smokinjoe73 is offline
Old 03-24-2013, 09:25 PM
supertrooper's Avatar
supertrooper is on a distinguished road
nice writeup
supertrooper is offline
Old 03-28-2013, 04:00 AM
stesrg's Avatar
Hi i will post some final photo's soon as i get it mot'd and ready for the summer Steve
stesrg is offline
Old 05-07-2013, 05:22 PM
jmathern's Avatar
jmathern is on a distinguished road
Quick newby question.... Is that a 6th Gen VFR800 Tank?
jmathern is offline
Old 05-07-2013, 07:32 PM
Quick answer contained in this very thread: yes
7moore7 is offline
Old 05-07-2013, 07:50 PM
jmathern's Avatar
I'm not sure where it was indicated in this thread that it was a 6th gen. It is obvious from the post that it is a vfr800 tank. Superbling put on a 6th gen, while Kai Ju put on a 5th gen. I'm just trying to match up a couple of things, as I just purchased what "appears" to be the 6th gen, but my knowledge is very limited.
jmathern is offline
Old 05-07-2013, 08:25 PM
Oh snap for some reason I thought they all were VFR800's being used. Pay no attention to me then...
7moore7 is offline
Old 05-07-2013, 08:59 PM
jmathern's Avatar
Nevermind.... It is a 5th gen.
5th Gen - '98 to '01
6th Gen - '02 to '09
jmathern is offline
Old 05-08-2013, 04:11 AM
Tebs's Avatar
Tebs is on a distinguished road
Nice write up very helpful!
Tebs is offline
Old 08-03-2013, 09:35 PM
bpw
bpw's Avatar
bpw is on a distinguished road
Oh I need a tank anyway, this is getting me pumped up. Give us a pic man, we dont care if its done completely I just want to see whats going on there...
bpw is offline
Old 12-19-2013, 05:57 AM
Codeblue's Avatar
Codeblue is on a distinguished road
GOod work mate, got any more pics of the whole bike with the new setup?
WHat is the capacity difference of the tanks?
Codeblue is offline
Old 12-19-2013, 01:44 PM
Location: South of Live Free or Die & North of Family Guy
I guess that works, the only thing is I would be a bit worry about the family jewels, a little in the way I think...
NHSH is offline
Old 12-19-2013, 04:49 PM
Well take off, eh.
Jack Flash's Avatar
Jack Flash is offline
Old 07-25-2014, 03:41 AM
stesrg's Avatar
RANGE !!
Sorry have not been on here for a while , as I purchased a YVPS 31K AND A 750 KETTLE ;-)...........
So the final result , done some touring and the range is around 150 miles till the light comes on but I did bend the steel up a little to give me more on the reserve so safely do 160 then fill it , average speeds 70 mph occasional blast to 140 so as it was before a great improvement ...
as the crown jewls being affected my stomach fits snugly into the tank so keeps the away lol ......
stesrg is offline
Old 04-28-2017, 03:39 PM
theosagekid's Avatar
theosagekid is on a distinguished road
THIS THREAD NEEDS TO BE A STICKY IN THE KNOWLEDGE BASE :-)
I'm taking a printout of it to my shop on Monday.
theosagekid is offline
Old 04-28-2017, 04:15 PM
Hangfly's Avatar
So he never posted photos of the completed bike showing the VFR tank?
Hangfly is offline
Old 04-28-2017, 04:50 PM
Check out Kai's write up. Plenty of info, even had me thinking about it for a while.
new-guy-his-vtr
Wolverine is offline
theosagekid
05-03-2014 06:38 AM
AC COBRA
05-10-2007 08:24 PM
superbling
05-09-2007 11:01 PM
marmaladedad
06-05-2006 10:17 PM
Besucher98
10-24-2005 03:52 AM
Quick Reply: VTR TO VFR TANK Pro Modification !!
