K&N Filter install
Old 11-03-2006, 06:37 PM
timdske's Avatar
timdske is on a distinguished road
K&N Filter install
Hello,
I'm new Superhawk owner, the bike is a 2003, and this is my first time writting in. My question is, I just replaced my stock air filter with a K&N filter.
I noticed that the stock air filter had 2 rectangle cones that go into
what appear as breathers. The K&N filter doesn't have these. Is this somthing
that I should worry about? Should the foam material be removed? Or is it
okay being left in there w/o anything holding them in place?
Thank You
timdske
timdske is offline
Old 11-03-2006, 06:58 PM
EngineNoO9's Avatar
you do have a jet kit right?
EngineNoO9 is offline
Old 11-03-2006, 07:07 PM
timdske's Avatar
I was told the bike did. How would I be sure?
timdske
timdske is offline
Old 11-03-2006, 08:04 PM
EngineNoO9's Avatar
whatever jets came in the bike before with the stock filter won't work with the k&N so you'll need a new kit
Old 11-03-2006, 09:56 PM
Slacker
BeerHunter's Avatar
Missing Plugs
If you bought the filter new, it should have come with 2 rubber plugs that cover those breather holes. Double check the box that the filter came in to see if you can find them. If those holes are allowed to vent directly into the airbox, the float bowls in the carbs will have negative atmospheric pressure which will cause the engine to run like a 3 legged horse at the Kentucky Derby. (well, maybe not quite that bad)
If you purchased the filter second hand, the seller may have neglected to include these plugs with the filter. Get ahold of that person and request the missing parts.
BeerHunter is offline
Old 11-04-2006, 04:47 PM
RickB's Avatar
FWIW my stock jetted '02 seems to run just fine with the K&N filter...
RickB is offline
Old 11-04-2006, 05:56 PM
.....everything he just said....yeah it's supposed to come with two rubber triangular plugs that fit in there.
captainchaos is offline
Old 11-04-2006, 09:22 PM
timdske's Avatar
Thanks guys,
Like a dumb @ss I didn't look in the box, I found the pieces and the bike runs
great.
timdske
timdske is offline
Old 01-05-2010, 03:12 AM
viperslayer09's Avatar
viperslayer09 is on a distinguished road
So really just how bad is it if those rubber plugs aren't included?
viperslayer09 is offline
Old 01-05-2010, 06:12 AM
comedo's Avatar
If you use the K+N without the triangular plugs, the motor will suck in the little foam filters the plugs are designed to cover and the motor will drawn in unfiltered air from beneath the air cleaner box.
comedo is offline
Old 01-05-2010, 05:10 PM
is there anywhere to get those plugs or the foam filters? My filter is not a K & N it was an aftermarket stock replacement, and definetely didn't come with the plugs
Old 01-05-2010, 08:59 PM
comedo's Avatar
As far as I know, the K&N is the only air filter for the VTR that requires plugs. The foam filters are a stock Honda part.
comedo is offline
Old 01-06-2010, 04:55 AM
c-dub's Avatar
c-dub is on a distinguished road
I was missing my plugs... k&n mailed me some at no cost.
c-dub is offline
Old 04-24-2010, 07:37 PM
fja268's Avatar
fja268 is on a distinguished road
I'VE GOT AN "02" SUPER HAWK N AS FAR AS I KNOW, I'VE GOT STOCK JETS. I DID A BAFFLECTOMY N IT RAN FINE BUT I JUST PUT A K & N AIR FILTER ON N IT'S MISSN LIKE HELL BETWEEN 2500 - 3500 RPM'S. SO NOW WHAT ?
fja268 is offline
Old 04-24-2010, 07:42 PM
jay956's Avatar
search button and lower case letters
jay956 is offline
Old 04-24-2010, 08:32 PM
I take it you must be a jet kit salesman... or have stock in Factory Pro.
inderocker is offline
Old 04-24-2010, 08:42 PM
2nd mouse gets the cheese
Little_Horse's Avatar
lol, well he obviously used the search button since he found this old thread... but yes my ears do hurt.
Little_Horse is offline
Old 12-26-2016, 10:32 AM
finepooch's Avatar
search thread actually helped me, wow.
alas i still have a question. the foam in those breather ports was disintegrating so i took them out. there was actually bits of foam inside the post filter area of the air box. my oem air filter was a mess so it is not going back in. if i order the k&n filter do i need those foam filters or do the two block off pieces eliminate the need for that foam?
Attached Thumbnails K&N Filter install-img_2731.jpg   K&N Filter install-img_2733.jpg   K&N Filter install-img_2735.jpg
finepooch is offline
Old 12-27-2016, 04:46 AM
Let the K&N bashing begin.
xeris is offline
Old 12-27-2016, 06:10 AM
I've been using one for I'd guess 6-7 years with ZERO issues. I'd invite any one of the nay sayers to ride my Hawk...
Seriously, I live in south central Pennsylvania, let's go for a ride.
Wolverine is offline
Old 12-27-2016, 06:43 AM
I was just hoping to incite heated controversy.
I really have no idea how a K&N would perform on my bike. I plan on finding out as I'm due for an air filter replacement. I have a K&N that came with (bonus) an air box I picked up from Ebay. Who knows, it might be better than a **** star moving in next door.
xeris is offline
Old 12-27-2016, 08:07 AM
K&N's suck harder than **** stars, but, at least they aren't as bad as the stock Honda filter.
VTR1000F is offline
Old 12-27-2016, 08:11 AM
Who would want more air entering the engine anyway... asthma is a good thing right?
Old 12-27-2016, 08:15 AM
finepooch's Avatar
i ended up ordering an oem honda filter. i also ordered the two little breather filters. my original breather filters were crumbling so i would rather use something else, but what? even a piece of t shirt cotton material would be better than those oem foam pieces.
Old 12-27-2016, 12:58 PM
VTR virgin
Cadbury64's Avatar
Before I read on the net that it was a Bad Idea, I too installed a K&N filter into my stock VTR. No problems here either after more than 2 years.
Cadbury64 is offline
Old 12-29-2016, 07:55 AM
CrankenFine's Avatar
Prediction: in 2017 several forum members will try K&N filters as a direct result of this newly revived thread.
CrankenFine is offline
Old 01-20-2017, 08:05 AM
ion
n( . )( . )b
ion's Avatar
ion is on a distinguished road
Should I use a K&N air filter, or should I just pour playground sand directly into the carbs while holding the throttle WFO?
ion is offline
Old 03-21-2017, 12:09 PM
thephatboi's Avatar
thephatboi is on a distinguished road
better than OEM air feeelter....
Ok so I don't wont to fall for any Bad Ideas™ from the web, haha, so if not a K&N what do you guys recommend for better air flow than the stock OEM filter? My 2001 has Two brothers exhaust and I assume has been rejetted (it came with the pipes on it) because it runs pretty nice, but I need to replace my air feeelter...has stock one now, probably original.
thephatboi is offline
Old 03-21-2017, 12:48 PM
Wicky's Avatar
Just replace with standard filter if it's running alright.
Might be worth getting it on a dyno to see if it's optimally set up for the exhaust.
Wicky is offline
Old 03-21-2017, 01:42 PM
thephatboi's Avatar
filter
Honda OEM or are those Emgo filters ok?
Quick Reply: K&N Filter install
