84 CB700CS compression
Old 02-08-2021, 06:18 AM
jhawkins14's Avatar
jhawkins14 is on a distinguished road
I just purchased an 84 CB700CS with 24,00 miles in good condition overall and found 2 cylinders with lower compression.
4-85
3-130
2-125
1-30
I have not gone further with the diagnosis yet but hoping for information on common or possible problems for these bikes.
Thanks, Joel
jhawkins14 is offline
Old 02-08-2021, 11:35 AM
VTR virgin
Cadbury64's Avatar
IIRC (and I am getting old) the CB700S engine uses hydraulic valve lash adjusters (same as the CBX750F that I owned back in the day). May be an issue with an adjuster that is keeping a valve part open?
Cadbury64 is offline
Old 02-09-2021, 04:13 PM
Having worked on a 84' Nighthawk 700 recently, I can confirm that it does have hydraulic lifters. Shaft drive, frame front down tubes used to move oil to and from the cooler, gear indicator, gas gauge, (for the day) state of the art fork tech, superior build quality.
Good call on a stuck lifter.
xeris is offline
timc
05-17-2020 08:20 PM
ACE VenTRa
11-26-2019 12:27 PM
havoc7685
08-01-2012 09:55 AM
superchickencornermonster
03-29-2011 12:07 AM
digitaledge
06-01-2008 07:18 PM
Quick Reply: 84 CB700CS compression
