backfire on deceleration after new exhaust
Old 04-05-2015, 12:18 PM
moto gp wannabe
dutchdude's Avatar
dutchdude is on a distinguished road
I acquired a new to me Yoshi exhaust system - full system. Installed it over the winter and find that I have a backfire through the pipes on deceleration.
Would this be a lean condition?
Bike runs great with new pipes , good top end and midrange. just a nasty backfire when I cut the throttle/
I had the carbs pretty well set up before, and had 2 bros slip on ,
have done the TPS and pair removal stuff, long ago.
I don't recall my jetting set up right now - but I am about to go look it up again, basically it was set up per hawks carb thread.
any input appreciated - thanks
dutchdude is offline
Old 04-05-2015, 12:55 PM
Wicky's Avatar
Is the exhaust system all sealed - with new crush copper manifold gaskets and if applicapple to your aftermarket system: graphite seals between the header & link pipes, and all securely clamped up?
www.vtr1000.org ? View topic - Gaskets - pipe and silencer
Also you might need to rejet for your freerer flowing system.
Wicky is offline
Old 04-05-2015, 01:08 PM
I agree check the system for leaks before getting into the carbs
8541Hawk is offline
Old 04-05-2015, 04:12 PM
twist's Avatar
question: best way to install header gaskets without crushing them? I did mine and it was really tight and wanted to deform the gaskets at the muffler.
twist is offline
Old 04-05-2015, 04:57 PM
moto gp wannabe
dutchdude's Avatar
yeah speaking of exhaust leaks -
found a bothched (to be nice) repair to the carbon fiber on the can , a bunch of rtv hidden under the metal strap - which of course blew out during my shakedown ride.
so - now my Yoshi's are 1" shorter but back together
also backed out mixture screw 1/2 turn- that seemed to help - still a little popping but not as bad as first run this morning. thanks
ChillyWaa
01-09-2014 08:39 AM
doomcookie
01-27-2012 11:14 AM
AngryOlaf
11-12-2009 09:29 PM
01SuperChicken
12-03-2008 09:54 AM
SuperHawkSF
11-26-2007 06:21 PM
Quick Reply: backfire on deceleration after new exhaust
