Jeezus f***in' ch***t!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
#36
A new crank has been ordered... thankfully they are still available from Honda (!)..... I will get this one balanced to the pistons and rods too, though I will give the matter of fitting an OEM (unmodified) flywheel some thought.....
#41
#42
As Stephan alluded to, aggressive cams were the root of the problem on failed cranks in heavily modded engine. This is why HRC made a run of 20 billet cranks (very expensive and no longer available), these having a gradual radius where the counterweights meet the shaft, eliminating the 90 degree corner which was the start of stress fractures and ultimately failures.... This is not, however, supposed to be a problem for stock or Stage 1 engines.... though 150K miles on, it may have finished mine off.... won't know until I see the failed crank.... after having communicated with Roger D, the new crank will be getting balanced as well, and lightened flywheel will go back on.... still debating what I will do cam-wise.....
#43
Location: South of Live Free or Die & North of Family Guy
#45
rod bolts came in.... all told, it cost me just shy of $300 CAN for 4 bolts (debated recycling the old ones then thought about what happens if they fail...)... man is this gonna cost me a bundle again..... *sigh*
#46
sucks you have to go through all this!! I have test ridden a FZ-09 before. They sure are neat, but I just didn't fall in love with it. I only had it in the low-power "rain" mode (all the dealer would allow) and it would still pull the front end off the ground w/ ease. Lots of low end grunt with plenty up high!! Reminds me of a more tame speed triple (love those!!) Good luck with all the repairs!!
#48
2015 Yamaha FJ-09, Street Motorcycle, Supersport Touring
Test rode one on Saturday..Probably as close as ther're going to come to a faired FZ..
#50
Just for future reference there is a guy in Kentucky that specializes in crank rebuilds.
Mr.Crackshaft.com
He does really good and fast work and I used him a few times on my XR426r supermoto for the street that I installed the crank from a TRX400 four wheeler making the XR electric start with reverse!
With shipping, balancing, Razor Rod kit the cost was under $200 bucks plus he tosses in a cool T shirt.
SIRR1
Mr.Crackshaft.com
SIRR1
#51
Mr.Crackshaft.com
SIRR1
Mr.Crackshaft.com
SIRR1
Though I will use Falcon cranks for the VTR
#52
The bearings are in............... the bearings are in................... the bearings are in................
Oh, have I mentioned? The bearings are in!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
P.S. special kudos to my bud Jack Flash for going out of his way to help me with this
#53
Awesome news! Looks like you and I might get our bikes together at about the same time. My engine is together, just waiting for the frame to be done at the powder coaters. Then ASSEMBLY!
#55
and so the adventure continues.....
just got back from Phase I of my summer vacation (with my daughter), ever-hopeful to find my bike up and running upon my return......... No sir not to be.... (yet again!), shop decided to replace the head gaskets (not sure it was necessary, but alas, the heads are off so they need replacement now).... more waiting....... I am beginning to wonder if I will get thing back before the snow flies......
