This annoying seat
Old 10-18-2016, 03:45 PM
Force128's Avatar
Force128 is on a distinguished road
This annoying seat
My seat latch in the back does not want to function properly
99 vtr US model
Only thing in a year and a half this bike has ever given me an issue with
The latch will stay closed if you take it off and put it closed andbolt it back and put the seat down and youre fine and it's latched
Once you unlock it
It won't return
And the seat likes to moves about unlocked
Anyone know any tricks outside of copious amounts of pb to make it work or a place to buy them that isn't crazy expensive
Force128 is offline
Old 10-18-2016, 04:56 PM
Lube the lock.
CruxGNZ is offline
Old 10-18-2016, 06:55 PM
Force128's Avatar
Originally Posted by CruxGNZ
Lube the lock.
Also the key part returns to normal position but the actual latch does not
Force128 is offline
Old 10-18-2016, 09:23 PM
Yes lube it now or it will fail permanently and you will be on here asking how to get a seat off with no working latch. Don't ask me how I know.
The mechanism is cheap on ebay but lube it or loose it.
smokinjoe73 is offline
Old 10-19-2016, 01:42 AM
RedStormJ's Avatar
take the latch apart and clean it real good then some white petrolium or the like to it.
RedStormJ is offline
Old 10-19-2016, 05:21 AM
If your problem is the same as what I had with the seat, then you'll need to bend, to a more perpendicular position, the wire loops that are attached to the sub frame. Worked for me.
xeris is offline
Old 10-19-2016, 11:22 AM
finepooch's Avatar
my latch mechanism **** the bed years ago. i replaced and carried on.
finepooch is offline
Old 10-19-2016, 11:37 AM
sabermammoth's Avatar
sabermammoth is on a distinguished road
If you lube don't use wd40 use like silicone. Wd will gum up after a while.
sabermammoth is offline
Old 10-19-2016, 01:18 PM
As for lube, triflow is really some of the best, but no matter what you have to keep your eye on it. It is just dying to fail again.
Old 10-24-2016, 04:23 PM
Force128's Avatar
Thanks for all the replies
Ended up taking it part cleaning the heck out of it
Moved the seat hook more rear
And replaced it with a more robust spring
Seems to be so far so good
Force128 is offline
Old 10-24-2016, 05:01 PM
Don't got too strong on that spring, don't want to make it an ejection seat.
Old 12-02-2016, 08:02 PM
Klaudt's Avatar
Klaudt is on a distinguished road
Seat lock help
Can someone post a picture of the seat lock and the cable under the seat , I bought a basket case and can't figure how the cable routs without getting a kink in it, maybe I have the lock installed wrong but it seems like it will only go in one way ? Thanks, 2003 superhawk
Klaudt is offline
Old 12-03-2016, 01:38 AM
Wicky's Avatar
www.vtr1000.org ? View topic - rear seat cover stuck
and you might find it useful to download the Honda Service manual for the VTR with useful diagrams
Wicky is offline
Old 12-03-2016, 10:01 AM
Klaudt's Avatar
Thanks for the photo
From the looks of the photo I had it right it just seems like the cable has too much of a bend in it , but as long as I can get the seat off when needed all is good . My 500.00 superhawk should be on the road soon. Thanks again for the photo
Klaudt is offline
Old 06-10-2017, 05:19 PM
KLR996's Avatar
KLR996 is on a distinguished road
Is it possible to get a replacement seat lock mechanism these days? The bike I picked up has a broken one. I think the whole thing needs to be replaced.
KLR996 is offline
Old 06-10-2017, 06:27 PM
Yeah ebay
Old 06-19-2017, 06:30 PM
KLR996's Avatar
LOL! Mine wasn't "broken". Once I looked at it, I found it had come apart and the PO took it apart the rest of the way. I reassembled it and lubed everything. Works like new.
KLR996 is offline
twist
01-09-2013 04:55 PM
nick.p0306
03-09-2010 07:57 PM
Gerrit
10-17-2008 12:25 AM
sempar paratus
05-31-2008 07:20 PM
SD Hawk
02-19-2008 11:05 AM
Quick Reply: This annoying seat
